SOURCE: i'm using a nokia e71,done
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Default 6 Digit Security code: 000999 or 1122
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
OR:
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
SOURCE: my nokia E71 got locked
Be sure to double check the PIN code and the confirmation or re-type PIN code is match.usual PIN code entered is just 4 digit.Try to enter 1234 and re-type it again. Better turn your mobile for an hour and remove the battery then try it again.
Good luck,,,
