IF YOU WANT TO DO IT YOUR SELF IS NO BIG DEAL YOU'LL
NEED A SET OF MINI SCREW DRIVER .AND A SMALL MAGNET TO KEEP SCREWS TOGETHER AND TWO PIECES OF THIN PLASTIC TO SEPERATE THE BACK PANEL. PREPARE A WORK SPACE..REMINDER SOME LAPTOPS THE BACK SNOPS TOGETHER AND SOME ARE SCREW TOGETHER,I WILL ASSUME THAT YOUR LAPTOP THE BACK IS SNOP TOGETHER.IF NOT YOU GO WITH REMOVING SCREWS.WHEN FINISH USE THE THIN PLASTIC TO PRY
AND SEPERATE BACK FROM FRONT PIECE.ONCE YOU HAVE THE BACK OFF NOW TRY MOVING THE SCREEN SEE IF IS TIGHT IF IT IS, THEN YOU CAN LOOSEN THE HINGE SCREWS AND TIGHTEN THE SCREWS TO YOUR PREFRENCE.....
NOW!! IF YOU HAVE A PAY-PAL ACCONT GRATE IF NOT YOU GET ONE..
NOW YOU GO TO E-BAY [ TYPE IN THE MODLE NUMBER OF YOUR LAPTOP, YOUR LOOKING TO BUY ONE FOR PARTS' YOU WANT ONE THAT HAS A GOOD BACK PANEL......
DON'T FORGET TO MAKE A PLAN.
SOURCE: acer extensa 5420 - crack on lid near both
Anything cosmetic is never covered under warrany unless there is a recall from the company and I don't remember hearing any recalls from Acer recently.
Only thing I can suggest is to get a hold of Acer and explain the situation and see if threre was or is a recall on your model.
My best solution, go to this page:
https://secure2.tx.acer.com/FixMyAcer3/FixMyAcer.aspx
Either fill out the form or call the number and see what they can do.
Let me know what they say and If they can't help at all then there is other routes we can try to take to keep costs down.
SOURCE: Acer 9300 Laptop CRACKED BACK COVER NEAR HINGES
Dont have solution im sorry but just word of warning hubby carefully replaced back cover and then the screen died 2 days later! send it to authorized repairer dont do what we did and DIY its expensive business!!!
SOURCE: The back lid of the
new hinges are not available in the market what you can do is that
Testimonial: "thanks for the feedback"
