Pilot light switch is usually rated 15 amp.
Check amp rating of device.
Check volt and watt rating on nameplate of water heater.
4500watt element divided by 240volts = 18.75amps
http://waterheatertimer.org/Figure-Volts-Amps-Watts-for-water-heater.html
If you have 120Volt under-counter water heater, then add a comment.
I recommend using contactor to control water heater when using a switch rated for less than 30amp.
Contactor controls water heater. Switch controls contactor.
http://waterheatertimer.org/Ordinary.html
http://waterheatertimer.org/H230A.html
Thank you for replying.
Yes it's under-counter type
1500 watt
120 volt
1500watts divided by 120V is 12.5Amp and within rating capacity of switch. To see if switch is defective, use same pilot light switch and replace ordinary wall switch that controls incandescent bulbs. Otherwise, defective pilot light is suspect.
