The Jensen TV in our Coachman Freedom Express
camper worked fine and always found channels over the
air. I hooked up to a cable in a campground. Now I can't
get any over the air. I have switched back to AIR in the
channels tab, I run autoscan, it finds no channels and always
comes back and says to run autoscan?
Sounds like it is frozen. The coil is frozen therefore it cannot get good airflow through. Turn just the fan on without cooling for 3 hours and try again. Be sure filter is clean but possibly a refrigerant issue
You may be able to get around this via a digital hd tv decoder box and then have it on a hdmi input on the TV as a backup to the cable if you can't have both cable digital channels stored and aerial digital channels stored
Sounds like the TV may need to be on ch 73 cable rather than 60 air. Try switching the TV to 73, if it goes to 69 then put back on 60, if goes to 73 good. Once you have that set go to your TV1 and bring up the menu. Go to System Setup (6) -> Installation (1) -> Modulator Setup (5) and change the TV2 setup to either cable if on 73 or air if on 60 and the picture should come in if everything's hooked up.
Hope that helped! You can email me at [email protected] if the problem persists.
i had the same damn problem for 3 long hours but i found a solution
i have olevia 32 inch tv (720). all you gotta do is go to menu>setup>tv>auto channel search> cable> standrad search
