SOURCE: LG FLatron 22 Inch : model number (L226WTO - SF)
It's problem in properties of monitor.I have LG l226WTQ and i'm having home bad things like http://img.youtube.com/vi/MzQtRBtrvc8/default.jpg
I don't know how to solve this :'(
SOURCE: LG Flatron LCD Power Saving Mode
Hi, September 2008 and still problems happening with the LG screens. Mine is a Flatron W1942T.
I hit the screen as suggested (my old mum was a great believer in " if it won't work kick it", this applied to anything electrical, tele, vacuum cleaner etc.,) and guess what? my old mum was right. The screen came on.
Hope this works if it happens again. I'd turned everything off because of an electrical/thunder storm. Won't do that again.
Joan
SOURCE: How can I make fonts look good in an LCD monitor ?
The VGA connection should be fine; I have DVI and when I switched from analog, the difference was pretty minimal, to my eyes.
Is it just the fonts that are blurry, or everything? If fonts only, then this almost certainly suggests that running the ClearType tuner again would solve the problem. But this applies to all displays, so if one is good and the other is not, then this isn't it.
If everything is a little blurry, then this suggests one of two problems -- the first, you report trying, which is that the display adapter is set to a different resolution than the native resolution of the LCD monitor itself. Your display adapter should probably be able to drive 2 monitors (the built-in laptop monitor and the external monitor) at once. You should be able to set their resolutions separately.
Assuming Windows XP: Start > Control Panel > Display > Settings > at which point, you should see two monitors listed in a dropdown. Set them to their native resolutions there (using the slider bar, usually all the way to the right), and save.
If you do have the display resolutions set to their native resolutions for both monitors, then it's possible that your external monitor is messed up. A quick test would be to run the on-screen settings, usually from a button on the monitor itself. If what is displayed there is sharp and what is displayed from Windows is not, then this points to a problem with the display driver. If everything, even the on-screen display is blurry, then perhaps the monitor settings are messed up -- usually there's an option to restore to factory settings -- try that.
If that doesn't work, I'm probably out of ideas, unless you have further information.
SOURCE: Shade difference in lg lcd diaplay
Based on your description, it appears that the monitor is faulty. Since it is only a week old, you should have no problem exchanging it.
SOURCE: LG Flatron screen with green line
Hey man the screen is having manufacturing fault ...
please go and replace it immideatly.... with no doubts in your mind
regards
