Sometimes either a faulty coil begins to fail when it gets hot or there’s an igniter coil behind the flywheel that’s running intermittent when hot. Possibly.
Try cleaning the carb.
If you can remove the air filter and the engine will run for a bit with a couple of quick squirts of starter fluid into the carb, then the carb needs all of its orifices cleaned.
www.partsfortechs.com > Home > Generator Part Generator Parts Spark Plug # RS17YX for Onan 167-0272 on RV Gensets ... for this plug require the spark gap to be set at .025" (25 thousandths of an inch).
https://www.heartlandowners.org/.../39632-Onan-Gen-HGJAB-What-is-t... Jun 8, 2013 - 3 posts - 3 authors
Also what is the the correct gap on the plugs? ... brands · Generators; Onan Gen HGJAB What is the best spark plug and gap? ... Gap: 0.025
That is an un commanded shut down, check battery voltage on batteries powering the gen, check battery conenctions to the unit and any interconnecting charge solenoids.
