D-Link DWL-G700AP 802.11g/b Wireless Access Point Logo
Posted on Aug 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi, the power light on my d-link wireless access point is on and the LAN light is on but the WLAN doesn't light up at all. This started happening yesterday, before that, it was working fine. I connected the LAN cable to my computer and its working. Just the wireless is not working. Thank you for your help
Anonymous232
Level 3:
Genius:
  • D-Link Master 1,552 Answers
  • Posted on May 07, 2015
Anonymous232
D-Link Master
Level 3:
Genius:
Answers
1552
Questions
Helped
270022
Points
2945
Power-off the router. Turn it on.
Does the WLAN light show activity?
If not, it is "dead", and needs to be replaced.
5 Related Answers
Anonymous
  • 104 Answers
  • Posted on May 03, 2007
SOURCE: Laptop can't find access point!
Some laptops come with a button\switch or use key combination to turn on or off the wireless(to conserve power)! Refer to your user manual for exact instructions! If that didn't solve the situation then it could be your actual wireless card within the laptop is giving trouble! regards, babb
Anonymous
  • 126 Answers
  • Posted on Mar 18, 2009
SOURCE: LED for WLAN doesn't turn on, no wireless signal
ok now connect the laptop thruh lan and try to open router configuration...check ther wther ur wireless is on.....or try to reset your router ...and cross your laptop with othr router,reply
pontelemon
pontelemon
  • 538 Answers
  • Posted on Mar 27, 2009
SOURCE: D-Link DWL-810+ is used by wireless ISP does not function
http://ngia.rootforge.org/content/Hardware/DLink/Dlink%20810/dwl810_QIG_102.pdf
Anonymous
  • 107 Answers
  • Posted on Aug 11, 2009
SOURCE: lost internet wireless password
Reset the router
Open your browser and go to 192.168.0.1
Type admin as username
Leave the password blank
All the best!
Anonymous
  • 7 Answers
  • Posted on May 10, 2010
SOURCE: DWL-G700AP wireless Power LED and LAN Led works also not connect
lol
Hi people I have an airlive radio the power and wlan led are working whith the indicator of the wlan blinking but the Lan indicator light is off i have no wired connection to my computer.
The failure lies on the LAN side. You need to check back towards the server, somewhere there is a disconnection.
Does it supply Power Over Ethernet?
The radio only provides access to the server/router over the LAN.
If it cannot log on to the LAN it will not work.
I have a level one wap 0004 wireless access point. I also have a panasonic blue ray player that i am trying to connect the adapter too. The blue ray player has an ethernet connection. The 2 are now...
so, depending upon if you are connecting it with a cable or wireless it is a little different. Wireless sometimes has wps button too for a quicker config/connection.
I suggest you Check the manual:
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwiUnI_205zTAhUE7YMKHfM-Cv4QFggaMAA&url=http%3A%2F%2Fdownload.level1.com%2Flevel1%2Fmanual%2FWAP-0004(EN).pdf&usg=AFQjCNGJRGXedGyKrPDAD2yOSP0CIN39wA&sig2=Rq3EoRlhyzd_LmCLkg8VwQ
Often you go to the url of the routers IP address but you need to know that and the default username and password for administrator, which BTW you may wish to change so only you know it.
My dlink air plus in not working, but all the lights are one including, power, lan and wireless lan.......................
Try RESETTING the D-Link.
Press and hold the RESET button at the back of the routerwith the power ON until the LEDs flash at the time the release the RESETbutton.
Connect a LAN cable from the D-Link to your laptop/computer's LAN port, openthe browser on your laptop/computer and enter the D-Link's configuration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter) You can now change the default password.
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop withthe router's wireless settings.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
This AP is in network x.x.102.0, which has it's own DHCP server. Only lan-port and WLAN are used on AP. I need this AP not to have it's own ip-adress, but devices, that connect to it,using WLAN,...
Ideally, there shouldn't be any configuration needed. Access points are transparent and only work as a bridge between wireless and wired network so devices should obtain their IP info from your DHCP server not the access point by default.
If you face problems, then there might be a DHCP server in the access point, disable that.
good luck
Othman
Hello, i resetted a dlink dwl 2000AP wirrels acces point, and now afther set up, the wlan led doesn't light up any more
If the WLAN light wont come, first thing that you can try here is to reset the unit again, by pressing the reset button for 10 seconds to correct the problem and once you're done resetting the unit unplug power for 10 seconds and then check if the wlan light is back....
No lights(lits)on WLAN-No acces from the computer
WLAN light will give you the status of your wireless connection. If WLAN light is off, it might be a possibility that wireless has been turned off or worse is the device had stopped broadcasting a wireless signal. you may try using 192.168.1.1 to get into the setup page of the device to check if wireless has been disabled.
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
