Epson Stylus Multifunction Printer/ Copier/ Scanner/ Fax Logo
Posted on Feb 06, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have Epson SX600FW and am trying to set up the Fax capabilities plus have a phone attached to the printer. I connected the printer\fax Line to the BT socket and the phone to the EXT socket but got no dial tone on the phone. Do I need a different type of cable or is this setup not possible ?
  • Terry
    Terry Feb 06, 2018
    Hi m_s_fletcher, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Download and check the Fax guide for this model on the Epson web site:
    https://www.epson.co.uk/support?productI...
Terry
Level 3:
  • Epson Master 11,377 Answers
  • Posted on Feb 06, 2018
Terry
Epson Master
Level 3:
Answers
11377
Questions
Helped
4619898
Points
152765
Https://www.epson.co.uk/support?productID=2933#manuals
Download Fax Guide.
Note instructions for DSL phone line is different than regular phone line. The fax manual there has pictures of how that is done.
If BT is faulty, they offer support:
From the UK: 0800 800 150*From outside the UK: +44 179 359 6931*
Our repair teams are open:
7 days a week, 24 hours a day
* The cost of the call depends on the country and network you're calling from.
http://www.bt.com/help/home/contactus/#/landline/fix-landline-problems
5 Related Answers
gremlin11
gremlin11
  • 78 Answers
  • Posted on Dec 10, 2008
SOURCE: Epson cx11 outgoing fax problems
This is not an issue with you unit, this is an issue with your phone line. get your service provider to check the line. also remove the line from your fax and put a standard phone on the end, try to make a call and see what happens. if the same result occures, there is an issue with the line and not the fax.
Gremlin11
Anonymous
  • 239 Answers
  • Posted on Mar 02, 2009
SOURCE: INSTALLATION OF EPSON SX600FW
http://support.epson-europe.com/onlineguides/en/sx600series/html_z/p03.htm
this is the web site that explains how to connect to the network. i hope this helps.
please rate good.
If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
Anonymous
  • 3085 Answers
  • Posted on Jul 07, 2009
SOURCE: my Epson bx300f cannot send faxes, just says no dial tone?!!!
ALL fax machines are ANALOG devices and will not work on a DIGITAL PHONE LINE.
Anonymous
  • 121 Answers
  • Posted on Sep 16, 2009
SOURCE: Epson Artisan 800 trying to make a fax and it says
body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte_2/misspell.gif) repeat-x scroll center bottom; } Hi,
Please check your phone line followed by the connectivity between your phone line and printer/Fax..
You can go through the user manual else cam download the manual from the link below :-
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=108745&prodoid=63082419&category=Products
If your Fax doesnt work, let me know!
Thanks !
Anonymous
  • 677 Answers
  • Posted on Jan 30, 2010
SOURCE: EPSON Stylus SX600FW printer. Recently changed
Did you use Epson Genuine Cartridges?
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc. These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. Don’t waste too much ink in cleaning it.
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
1helpful
Epson 630 workforce won't fax to some numbers.
followed edger allans remedy and now faxes that where not answering before now are. i think mostly because i had it set to, 1 ring to answer and i changed to 6. thanks.
I have a new AT&T DECT6.0 single line answering machine and i'm trying to connect it to my Epson Aculaser fax ( the single phone line is phone/fax), however it's not differentiating the...
If this is a new machine, why haven't you contacted AT&T? Sounds like either it's a configuration problem in the answering machine or it's incompatible with your phone line.
1helpful
Where to plug in the phone line for the fax
You don't plug a phone line into this printer. It's not a fax machine itself. According to the user's guide (which you can download here), "To send a fax using this printer, you need to have the printer attached to a computer that is equipped with a modem and has Microsoft Fax installed."
What this means is that the printer is just serving as the input (scanner) and output (printer) parts of a stand-alone scanner, but you need your computer to connect to the phone line. Without the computer modem and Microsoft Fax software, your printer is, well, just a printer, with scanning capability.
Sorry! Thanks for using Fixya.
2answers
Able to send faxes but unable to receive.
you need to check how the fax machine is setup for receiving faxes. i recommend you try it first without the answering machine, to see if it works. if it doesnt, then it has to do with the auto answer or the number of rings not set right, if it does work, it could be that you need to set it to check for fax while the answering machine is answering, check the manual under answering faxes.
thanks adi
CAN NOT GET FAXES? I DO HAVE DIAL TONE IT IS ON
Here are some things you can try, hopefully one will help.
  1. Check for a phone connection in the correct input jack. Some printers with fax capability have more than one phone jack so you can hook up an answering machine or another phone “downstream” from the printer. Consult your instruction manual to determine the right connection for your printer.
  2. Ensure that you are running on an analog line. IP phones can not run most Faxes, even if you get a dial tone. Also in a corperate setting ensure that you are not on a digital line.
  3. If an answering machine is connected to the same line, fax reception problems can occur. These problems may be corrected by changing settings or phone line connections. If you have other faxes on the same line as this one, ensure that the "Rings to Answer" setting is set to a number equal to or larger than one for models that do not have an Auto Answer button. Same goes for your answering machines. On models with an Answer Mode setting, it should be set to Fax, FaxTel, or AnswerMachine depending on your setup.
2helpful
2answers
How do you set up fax phone on the HP officejet 6215
hi you really have a very good choice of printers is one of the best printers from hp
inorder to set fax on ur printer you should first be sure what type of telephone line you are using
there are 2 type of line 1 dedicated -> that is directly attached for fax and has no other telephone or TAM connected if you have this line you can directly attach the phone line on the printer line 1
the other type of line is shared that means you use the same line for phone and fax in this the connection should be as :- telephone line from wall jack to the printer line 1 then from printer ext port to telephone answering machine (if any ) then from answering machine to telephone (if u have a dsl line that means u use phone and internet from the telephone line then there will be 2 lines comming out of the splitter 1 to router and other to telephone here follow the shared line connection mentioned above using the line that goes to the telephone )
now power on the printer and press the setup button (menu) now navigate to basic fax set up press ok and then go to rings to answer it should be 4 rings now go back and go to advance fax setting and then to distintive ring (DRP) select all rings and press ok now run fax test if it passes then ur fax is set up try sending fax now hope this will help you
3helpful
My Epson bx300f cannot send faxes, just says no dial tone?!!!
2helpful
Our Epson Sylus CX9400Fax Series is not receiving or sending faxes. We have already done the phone call to India thing for 90 minutes. All settings were changed and tested. They are now back to factory...
Ok, here's a check list for you.
SENDING
Check the following:
  • Make sure the phone cable is connected correctly and verify that the phone line works by connecting a phone to it.
  • Make sure that your recipient's fax machine is turned on and working.
  • If you connected the Epson Stylus CX to a DSL phone line, you must install a DSL filter to the line or you won't be able to fax. Contact your DSL provider for the necessary filter.
  • If your phone line has static or other noise problems, turn off the ECM (Error Correction Mode) setting and try faxing again.
    Follow these steps to turn off the ECM setting:
    1. Press Setup.
    2. Select Fax Settings, then press OK. You see this screen:
    4. Select Communication, then press OK.
    5. Press cp_button_44_er.gif and select ECM. Then press cp_button_42_er.gif and set it to Off.
    6. Press OK.
RECEIVING
Try the following if you can't receive a fax:
  • To receive faxes automatically, make sure the Auto Answer light is turned on. To turn it on, press the Auto Answer/Space button.
  • Make sure paper is loaded.
    1. Press Setup.
    4. Select Communication then press OK.
    6. Press OK.
2answers
Epson ACULASER CX11NF incoming fax problem
Try this:
Unplug line from back of printer
Set the Incoming mode to autoswitching
set DRPD to Off so that it will recognize all incoming calls
** if possible call your telephone company and set a distinctive ring pattern for phone calls
replug cable on line port at the back of printer
then ask someone to send you a fax...
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
