Compaq Deskpro EN PC Desktop Logo
Posted on Aug 23, 2011
Very slow - Compaq Deskpro EN PC Desktop
My computer is very slow
slow only on internet or off that too.
tell when it is slow doing what, and when not slow.
all PCs are slow. compared to better PCs and Better ISP.
I will answer for slow all the time.
1: normal , old PC.
2: hdd bad and runs slow. (replace it)
3: OS unstated by you is infected, reload the OS fresh.
Della 12 Quart 1600-Watt Electric Pressure Cooker Multi-Functional Timer Slow Cook XL Part number: 048-GM-48261 Unable to get this cooker to slow cook.
it is possible that you have misunderstood the instructions
for a slow cooker you have low medium and high
press slow cook and on low and in 8 hours the food is cooked
I see from your statements that you expect the cooker to be set on slow cook but cook at a high temperature fast
if it says slow cook --9 hours and the temp is 125 degrees , have you waited 9 hours to see if it is cooked as the slow cooking process is by the gradual build up of heat in the container that is not expelled by radiation to the air
in a pressure cooker , that build up of heat also builds up pressure and so it cooks better
other solution--- if it is not right return it for a warranty refund or if out of warranty , junk it and get a different make
The handle to the lid melted. My fault, I tried to use the insert and lid in the oven. Is it possible to buy a replacement?
Melted my Crock Pot lid handle : slowcooking - Reddit
https://www.reddit.com/.../slowcooking/.../melted_my_crock_pot_...
RedditJul 23, 2015 - So I melted the Crock Pot lid handle.... I....it.... it all happened so fast. Then I messaged Crock Pot to see if they would mercifully send me a...
I have A proline slow cooker, unfortunetly the handle melted ...
www.fixya.com/support/t10606247-proline_slow_cooker_unfortunetly
Oct 3, 2011 - Question about Crock Pots & Slow Cookers. Open Question ... slow cooker, unfortunetly the handle melted last night and came off the lid. can I ...
Slow Cooker Replacement Parts ' Crock-Pot
www.crock-pot.com/parts/
Shop slow cooker replacement parts from Crock-Pot. Make sure your slow cooker is functioning ... Replacement Lid - Crock-Pot® 5-Quart Round Slow Cooker.
Crock-Pot® 4-Quart Oval Slow Cooker Replacement Lid ...
www.crock-pot.com/lids/...lid---crock-pot...slow-cooker/129960-000-00...
I need a manual for how to use
    Instruction Manuals at Crock-Pot.com.
    www.crock-pot.com/service.../instruction-manuals/instruction-manuals.ht...
    Browse our Instruction Manuals to find answers to common questions about Crock-Pot® products. Click here to view on our FAQs now.‎4 Quart -7 Quart Slow Cookers - ‎3.5 Quart Slow Cookers - ‎Specialty
    Manual Slow Cooker - Crock-Pot®
    www.crock-pot.com/service.../instruction-manuals/...slow-cookers/manu...
    Search. Home : Service & Support : Product Support : Instruction Manuals : 4 Quart -7 Quart Slow Cookers : Manual Slow Cooker. Your browser's Javascript ...
    Back to Basics: How to Use a Slow Cooker - The Kitchn
    www.thekitchn.com/back-to-basics-how...
    Apartment Therapy's The KitchnApr 21, 2010 - Prepare the Recipe - A good many slow-cooker recipes require only some basic prep .... Check out this website's post for easy instructions.
Windows xp slow down
Please explain your problem about slow down.In which process it slows down or it is always slow.
If it is always slow check your hardware configuration and increase some ram or hard disk.
3answers
I am confused is the russell hobbs slow cooker a slow cooker or is it a pressure cooker i am looking for a pressure cooker not a slow cooker
Russel Hobbs makes both a slow cooker and a pressure cooker - confusingly in Europe they call Slow Cookers pressure cookers. The only way to really tel is if there is a special lid with valves and locks (pressure cooker) not a glass or plain lid (slow cooker).
2helpful
2answers
PC SLOW BOOT UP-SLOW OPENING WORD DOC-SLOW E-MAIL RETRIEVAL-SLOW-SLOW-SLOW. WHAT SHOULD I BUY OR DO?
Slow performance is mainly caused by corrupted system or data files withing the hard drive. To maximize the full potential of the hard drive and when everything is slowing down formatting it and reinstalling the OS would be a great fix. If anything else fails, then it migh have had acquired too many bad sectors already and might need replacement.
32helpful
Slow cooker will only stay on warm. How do I put
This slow cooker has 3 settings LOW, HIGH, & WARM
When you plug the slow cooker in the display should show a "0". When you press the "COOK TIME" button, the display should go to 1 then 2 then 3 etc. each time the "COOK TIME" button is pressed. If 1,2,3,4,5 or 6 hours are selected, then the slow cooker will operate on the "HIGH" setting. If 7,8,9, or 10 hours are selected, then the slow cooker will operate on the "LOW" setting. To start the cooking cycle press the "ON/OFF" button. To interrupt the cooking cycle at any time, press the "ON/OFF" button. When the cooking cycle is complete, your slow cooker will automatically switch to the "WARM" setting. If the "ON/OFF" button is pressed when the the digital display shows "0", then the slow cooker will automatically start on the "WARM" setting.
If the "COOK TIME" button does not change the display numbers then unplug the slow cooker and hold both buttons down as you plug the slow cooker in. Keep the buttons pressed for a count of ten, then release them and the slow cooker should work correctly
10helpful
I can't set my slow cooker to high
If the slow cooker will not change the display from 0 to 1 to 2 to 3 etc. when you press the "COOK TIME" button, then unplug the slow cooker. Hold both the COOK TIME and the ON/OFF buttons down and plug the slow cooker into the wall. Keep both buttons held in for a count of 10 then release them. The slow cooker should work correctly now.
24helpful
2answers
Need a manual for the corningware sc60
The manual basically says... This slow cooker has 3 settings LOW, HIGH, and WARM. W hen you plug the slow cooker in the display shows "0". When you press the "COOK TIME" button, the display should go from 0 to 1 to 2 to 3 etc. each time the "COOK TIME" button is pressed. If 1,2,3,4,5 or 6 hours are selected, then the slow cooker will operate on the HIGH setting. If 7,8,9,or 10 hours are selected, the slow cooker will operate on the LOW setting. To start the cooking cycle, press the "ON/OFF" button. To interrupt the cooking cycle at any tim, press the "ON?OFF" button. When the cooking cycle is complete, your slow cooker will automatically switch to the WARM setting. If the "ON/OFF" button is pressed when the digital display shows "0", then the slow cooker will automatically start on the WARM setting.
If the "COOK TIME" button does not change the display numbers, unplug the slow cooker. Hold down both buttons and plug the slow cooker in and keep them pressed down for a count of 10. Release the buttons and the slow cooker should work now.
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
