I am afraid that I didn't understand your solution. Can you explain a little more in detail. I am a newbie.
Some printers automatically print on both sides of a page (automatic
duplex printing); other printers allow you to manually reinsert pages
to print the second side (manual duplex printing); and some printers do
not support duplex printing at all. To find out whether your printer
supports duplex printing, you can check the printer manual, contact the
printer manufacturer, or check the printer's properties by clicking Properties in the Print dialog box.
To find out whether your printer supports duplex printingThe options in the Print dialog box can vary depending on your printer options and configuration.
You can use the following clues to determine whether a specific printer supports duplex printing:
Notes
To manually set up a printer to print to both sides of a sheet of paperWith some printers, you can use the Manual duplex check box under Printer in the Print
dialog box. Word will print all of the pages that appear on one side of
the paper and then prompt you to turn the stack over and feed the pages
into the printer again.
You can also use the following procedure to set up your printer for manual duplex printing:
Note Depending on the printer model, you might have to turn and reorder the pages to print the other side of the stack.
