Hi betty2293,
Low resolution on your desktop can be for two reasons ,
Hope this helps...:)
Turn on the PC. Press F8 at booting into windows 7. It will display many options
Select the Enable low resolution video(640x480) then login to system.
then change the resolution as required
Right click on a empty space on the desktop and click on Screen Resolution.
Screen resolution refers to the clarity of the text and images on your
screen. At higher resolutions, items appear sharper. They also appear
smaller, so more items fit on the screen. At lower resolutions, fewer
items fit on the screen, but they are larger and easier to see. At very
low resolutions, however, images might have jagged edges.
For example, 640 × 480 is a lower screen resolution,
and 1600 × 1200 is a higher one. CRT monitors generally display a
resolution of 800 × 600 or 1024 × 768. LCD monitors can better support
the higher resolutions.
Whether you can increase your screen resolution depends on the size and
capability of your monitor and the type of video card you have.
Text and images are sharper and smaller at high screen resolutions
Text is larger and easier to read at low screen resolutions, but images are blocky and fewer items fit on the screen
Open Display Settings by clicking the Start button , clicking Control Panel, clicking Appearance and Personalization, clicking Personalization, and then clicking Display Settings.
Under Resolution, move the slider to the resolution you want, and then click Apply.
