SOURCE: toner end life
There are silver wire contacts on the left and right that are spring-loaded and touch on copper tabs on the cartridge. They may not be making proper contact. Wiping with some contact cleaner ona cloth may help, or failing that try brightening the surfaces with some fine Scotchbrite pad to help them make proper contact.
SOURCE: Magicolor 2430 DL vertical white blank stripes
remove PC drum and under that you can see laser glass, clean it and reinstall.
SOURCE: (the infamous) ?X toner not installed? error message
I just got off the phone with KM tech support for the same problem with my 2430dl. Take out the drum and remove the toner cartridges, then look inside the printer. You will see a piece of glass about 6" long. Next to it, on the right side of the printer, there is a little white plastic enclosure that contains three spring-loaded contacts; this is the sensor that reads the chips on the individual cartridges. First, try cleaning the three contacts with a swab/alcohol, as well as the chips on each cartridge. If this doesn't solve the problem, then the problem is likely with the sensor. The part number should be 4139-6306-02, and it runs about $5. This should solve the problem.
SOURCE: After replacing black toner cartridge printer displays Drum Low
Ask you companey that surives you printer to look at it
The drum and the black printer cartridge are two separate items. You will have to purchase a new drum for it. I just had to do the same thing and it ran me $150.00 at Staples.
