Question about Maytag Bravos MTW6600T Top Load Washer
Is the ul error message a problem with this washer? Does it get out of balance easily? I don't know how I could have more evenly distributed the load. The washer won't finish spinning, it keeps getting out of balance, then filling with water, then spinning, getting out of balance, filling with water, etc over and over. What can I do about this?
  • Maytag Master
  • 8,220 Answers
Items between tubs can cause the problem Service manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Aug 23, 2011
  • lsdykstra Aug 23, 2011
    There are no items between the tubs.
  • Dan Webster
    Dan Webster Aug 24, 2011
    Is the machine level?
SOURCE:
What does code uL mean. this comes on in the drain spin cycle
Hi, a UL error code means a load not balanced. The washer is running a load-balance correction routine. Please allow the washer to continue. If the dial is flashing and the washer has stopped, redistribute the load, close the lid, and press START/PAUSE.
Aug 14, 2016 | Whirlpool WTW8200YW 4.6 cu. ft. Cabrio...
I get error code ul several times with every load
MAY HAVE A PROBLEM IN THE CONTROL BOARD, OR MORE LIKELY THE COUNTER WEIGHT OR BALANCE STABLELIZERS ARE BAD? THEY ARE WHAT BALANCES THE DRUM IN THE WASHER. AND CAN CAUSE AN UNSTABLE LOAD AND ERROR MESSAGE.
Sep 21, 2014 | Whirlpool WTW6400SW Cabrio Washer
UL bravo error code
Unbalanced load? Don't over stuff the washer. The load sensing moves the drum back and forth at the start. If it can't balance the load it will err.
Oct 16, 2013 | Maytag Bravos MTW6600T Top Load Washer
My washer is leval but continues to display ul code when spin cycle starts
UL does not mean the washing machine unit itself is unlevel, it means the load cannot be balance, possibly washing too small a load that the machine cannot distribute in drum evenly ( happens alot when only one or two items being washed), could be poor pump out (check filters if accessible) the machine tries to start spin with excess water or maybe it is a mixed load, lots of small items and maybe one or two large items that hinder the distribution. My machine is very temperamental when I do the sheets, because they get tangled during the wash part of the cycle and then the machine cannot get them balanced to spin. I sometime have to manual move the item about and then put it to the spin only cycle.Hope this helps
Oct 06, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
My washer keeps stopping at the spin cycle and says UL for uneven load. The load is not uneven and evey load does this
Hi.
UL is displayed when there is a balancing problem or when balancing sensor is defective.
The first thing to do is checking floor level and putting the machine at balance as explained in the user manual also try distributing the load
. If that does not work there are internal faults that may trigger the fault code. The balancing sensor and the electronic control board must be tested. The machine must be disassembled to locate the problem.
If you need parts see this tip explaining how to find parts and diagrams for most appliances: Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Jul 24, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
My washer gives an error code of uL everytime we use it. What can it be?
Unbalance Load
uL is displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalance the load.
Display clears if mini-cycle successfully rebalanced the load.
If the mini-cycle is unsuccessful, uL will flash until the door lid is opened, allowing the customer to view and redistribute
the load.
May 25, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
My Kenmore Elite Oasis top load washer will start when is ready. We press the start button several times and hold it down for minutes at a time then maybe it will start. Plus even the smallest load will be...
If the washer is shaking and actually going out of balance and generating the UL error and the drum is empty the most likely cause of this problem is something under the spin basket.Clothes can end up under the spin basket and cause it to turn crocked and cause the out of balance. First I'd recommend removing the spin basket and check under it for any clothing or other obstruction that might cause the out of balance. Here is a diagram of how to Check.. Click Here
May 22, 2011 | Kenmore Washing Machines
My washer has an error message "uL", the washer is full of clothes and water; but won't do anything...what should I try?
Unbalanced load uL is displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalance the load.
the load.
Mar 02, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Ul code about 10 to 15 seconds into spin cycle machine is level code comes up even if i run it empty
Hi
Thanks for using FixYa. UL is displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalance the load.
• Display clears if mini-cycle successfully rebalanced the load.
• If the mini-cycle is unsuccessful, uL will flash until the door lid is opened, allowing the customer to view and redistribute the load. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 22, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My kenmore elite oasis keeps stopping on spin and flashing ul it is a top loader king size capacity
UL = uneven load.
Re-distribute clothes and re-try.
If still no-go... the load balance sensor is likely to blame.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 23, 2009 | Kenmore Elite 45986 Front Load Washer
Maytag Bravos MTW6600T Top Load Washer Logo
233 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
