Hilsu198,
Have you tried restoring the unit back to the default setting? If not, please follow the steps below.
1. While viewing a line settings status, press SELECT to view the line settings options for that line.
2. Scroll down to RESTORE DEFAULT LINE SETTINGS?
3. Press SELECT again.
4. If you are sure you wish to restore all line settings, press SELECT again.
Hope it helps.
Thank you for using FixYa.
Try the star key. If that does not work please try the following.
TONE/PULSE DIALING
This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for touch-tone use. To set to tone or pulse dialing:
1. Press and hold the program button for two seconds. You will hear a beep.
2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing.
3. Press the program button again. You will hear a confirmation tone.
Hope it helps.
Done that already, it will only let me do a restore system in the system settings. I know it's the setting for switching between tone and pulse dialing but can't find out how to switch that anywhere and I must have hit it by accident. I have a huge conference call in the morning that I have to get this working for. Thanks for any help.
