Many of the newer A/C window units do not drain the water, but use the fan to splash it up on the coil to evaporate it and help cool the unit...
You can drill a hole in the back corner to drain it, but watch that you don't hit the coil and cause a freon leak...this also may reduce the efficiency a bit...
heatman101
Testimonial: "Very helpful. Just understanding the way the device works helps alot. Thank you"
