There should be a reset button on the back of the router take a small pin and push and hold for 30 sec that will set the router to factory defaults you will loose any settings you have on it and will have to reconfigure it I have included the manual
http://www.adtran.com/pub/Library/Manuals/Default/Total_Access_600_Series_System_Manual.pdf
Take a look at the manual that is how I found the answer
Restore factory default settings
This setting restores the factory defaults based on the location of the cursor. If the cursor is on an interface line (in the INTERFACES menu), then only the selected interface is updated to factory defaults.
F
Copy selected items to the clipboard
The amount of information you can copy depends on the cursor location when you press
If the cursor is over an editable field, only that item is copied.
If the cursor is over the index number of a list, then all of the items in the row of
the list are copied. For example, if the cursor is over the selection # field in the
INTERFACES screen, all of the information associated with the interface is
3. Factory default the Total Access 612/616/624 by one of the following methods:
• Select SYSTEM UTILITY > TERMINAL MODE. At the > prompt, type fac. You will then see “Restore
Factory Defaults and Reset Unit? (press Y).” Press the Y key to confirm default. The unit then resets.
• If connected to the CRAFT port, power reset the unit and then restore power to the unit while
holding down the F key. You will then be prompted to confirm the factory default.
4. In the ATM code, the upgrade was successful if the following two things occur:
• The SYSTEM INFO > FIRMWARE REVISION field does not display Error
I check on the back of the router and there is not a reset button?
