Tissot T-Touch T33759851 Logo
Posted on Jan 17, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Tissot touch will no longer sync - initially when in compas mode the hands were no longer aligning in a straight line and after using the compas mode i need to resync each time. Now the watch will not prperly sync no matter how many attempts i make - do I need a new batttery (it is ~ 5years old)?
  • Doug Johnson
    Doug Johnson Jan 13, 2021
    I am having the same problem. After multiple re-sets, it still is out-of-sync. Did you get your problem fixed?
Jerry Greenberg
Level 3:
Genius:
  • Master 1,691 Answers
  • Posted on Feb 11, 2018
Jerry Greenberg
Master
Level 3:
Genius:
Answers
1691
Questions
Helped
735788
Points
3767
In this watch the battery should be changed after one year, depending on how often the features are used. After changing the battery the all reset should be done. Best to take it to an authorized service, and not any non authorized place to change the battery. Get in touch with Tissot for the info about where to bring the watch.
5 Related Answers
Anonymous
  • Posted on Aug 29, 2007
SOURCE: synchronizing the manual and digital clocks
Push the middle button then touch the centre screen selecting the "nits" mode(24 C m), then push the middle button again for 5 seconds."Synchro" will appear on the display. By using pushers + and -, bring the two hands pre-cisely to 12 o'clock Incrementation of the minute hand(3 steps=1 minute) Incrementattion of the hour hand(3 steps=1 minute) Press the middle button to validate the setting.
Anonymous
  • Posted on Jan 14, 2008
SOURCE: tissot t touch
there are sync instruction on the manual page on the web.
http://www.tissot.ch/data/usersmanual/138-en.pdf
1. Activate the Crystal.
2. Select the "units Mode".
3. Press and hold the "T" until it switched to "syncro" mode.
4. Now using the + and - move the hands to the 12 o'clock position.
5. Press "T" again to set.
Anonymous
  • Posted on Jul 18, 2009
SOURCE: Tissot t-touch analog time is out of sync with
This is the tried and tested solution from this very nice gentleman. Many thanks to him (Ha Bi):
  1. Press and hold on to the T button until it beeps
  2. Touch the middle of the screen to change digital display to unit selection
  3. Press and hold the T-button until "Synchronize" comes up in the digital display
  4. Use the + button and - button to align the hour and minute hand to 12:00.
  5. Click on the T-button again. Congrats, you're done!
  6. Enjoy~
Must see blog for all T-touch users
http://myhabi.blogspot.com/2008/10/tissot-t-touch-battery-change.html
Anonymous
  • 5 Answers
  • Posted on Apr 26, 2010
SOURCE: the digital and hands display different times on my Tissot Touch
Anonymous
  • Posted on Nov 08, 2010
SOURCE: how do I change the time on the tissot 1853 touch
  1. Locate the screw on the side of the watch face. This screw is what you will use to set the time on your watch. Water-resistant watches have a screw-type crown, and the screw must be turned toward the body (unscrewed) before it can be pulled out for further use. If the watch is not water-resistant, the unscrewing is unnecessary.
  2. 2 Pull the screw gently outward. The screw can be pulled outward in two positions. The first position sets the date and day. Pull the screw out farther (into the second position) to set the time.
  3. 3 Turn the screw either clockwise or counterclockwise to move the minute and hour hands to the desired time. Push the screw all the way in (and turn it away from the body if you have the water-resistant model) when you are finished.
    Digital Watch
  4. 1 Locate the three buttons on the side of the watch face. These are the buttons used to set the time. The top button is the "+" indicator for increasing the numbers. The bottom button is the "-" indicator for decreasing numbers. The center button is to activate the setting mode.
  5. 2 Press the center button in for one second. The watch will beep.
  6. 3 Press the top "+" button for two seconds. After the watch beeps, you can begin setting the time.
  7. 4 Press either the "+" button or the "-" button (depending on whether you want to increase or decrease the numbers) to set the time.
  8. 5 Press the center button when you are finished. The watch will beep. This validates the setting. The seconds will revert to zero.
Read more: How to Change the Time on Tissot Watches ' eHow.com http://www.ehow.com/how_5934972_change-time-tissot-watches.html#ixzz14ifvni46
1helpful
3answers
How do I reset my tissot t touch expert
Steps to Synchronize the Hands
  1. Press the centre pusher (T). The watch should beep once.
  2. Touch the centre of the touch-sensitive face until opt appears, in opt select 24H Cm (or 12H Fft or 24H Fft or 12H Cm) is shown in the digital LCD display.
  3. Press and hold the centre pusher (T) for approximately 5 seconds. The watch will beep once and then again, a second time, after 5 seconds have passed. After the second beep, the digital LCD display should read SYNCHRO. If not, return to step one.
  4. Press the upper pusher (+) to advance the hour hand until it is positioned exactly at 12:00. (PH press T button to to switch to minute hand adjust)
  5. Press the lower pusher (-) to advance the minute hand until it is also positioned exactly at 12:00.
  6. When both hands are aligned together and pointing directly at 12:00, press the centre pusher (T) to save the setting. The hands of the watch are now synchronized
9helpful
2answers
Setting my Tissot touch Navigator 3000
Per the manual: http://support.tissot.ch/usersmanual/140-en.pdf
When your battery begins to die, the hands are no longer synced.
After replacing the battery, go into local time mode (pressing the center of the crystal) until "Set" appears. Press the crown. Scroll to "ECO BAT", press and hold the crown for 5 seconds until "SYNCHRO" appears. Use the "+" button to move the minute hand and the "-" to move the hour hand until they are in the upright or 12:00 position.
Either press the crown again or wait until the watch automatically leaves the Set mode. Your hands should now represent the local time.
27helpful
2answers
The digital and hands display different times on my Tissot Touch
36helpful
2answers
My tissot toch hour and minutes are out of sync for instance at 10:45 it appears like the hour is on or past 11. Is their any way to re-sync them or reset them.
This is an expected, needed adjustment, and is addressed in the manual:
Syncronisation
32helpful
I need calibrate Tissot t-touch
Syncronisation sequence is in the user manual. syncronisation is as follows.. 1) Press T to activate touch system. 2)touch the screen centre to show units display. 3)hold T button for approx 5 secs till the hands point to 12o clock. 4)use the + & - buttons to control the minute and hour hands... you must syncronise them both to 12 oclock exactly. 5)when you have them both pointing to 12 exactly, press the T button to finish the sync. the hands will now go back to the time. If the hands often go out of sync, the battery is probably worn and will at some stage the 'bat' warning will appear. (this initially only flashes every 20 secs, so watch the display for over 20 secs to see the 'bat' warning. eventyually this becomes permanant display). Batteries normally last about 6 years
133helpful
4answers
Tissot t-touch analog time is out of sync with digital time. How do I res-sync them?
  6. Enjoy~
11helpful
2answers
Need to sync tissot t-touch hands to digital time, and other functions
Paste this link into your browser:
http://www.t-touch.com/flash.html
1)Close available countries window,
2)Click on T-Touch, then choose Stainless Steel,
3)On the right side of the window click on film tab,
4)In the left box in the window find all the functions
5)Watch and listen to instructions
6)Smile
Do not forget to rate, please.
26helpful
2answers
Tissot t touch
8helpful
3answers
Compass wont work correctly
if your hands aren't straight when you use the compass try this to sync the hands.
1. Press and hold the middle button to enter T-Touch mode.
2. Press the centre area on the face twice to display 24hr/12hr
3. Press and hold the middle button to enter T-Touch mode untill screen says sync.The hands will face 1200.
4. Press either the upper (East) or lower (West) button to adjust the compass hands. They should both face 1200.
5. Press the middle button to get back to 'regular' compass mode. Note that your offset setting will still show in the digital area.
144helpful
6answers
Synchronizing the manual and digital clocks
Top Tissot Watches Experts
Ngoro
john h
k24674
Are you a Tissot Watch Expert? Answer questions, earn points and help others
