Broderbund PrintMaster® Platinum 17 Full Version for PC Logo
Posted on Aug 22, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Converting files in printmaster to pdf files and as it switches over to converting, it goes to a printing in broderbund box and screen freezes and shuts down the program
Anonymous
Level 3:
  • Master 2,229 Answers
  • Posted on Aug 22, 2011
Anonymous
Master
Level 3:
Answers
2229
Questions
Helped
564149
Points
6804
I'm not familiar with the conversion in Printmaster, but here is a simple solution:
You can use Cute pdf writer.
Go to www.cutepdf.com and download the free utility. The nice thing about this is it will work as a "printer" for anything on your computer you need to print--in pdf format.
In essence, it becomes a printer--you choose to print whatever it is you normally print and chose cutepdf as the printer and it prompts you for a file name and there you go!
1helpful
How do I remove fonts from The Printshop 23.1?
Windows programs install fonts in the C:\Windows\Fonts folder. The fonts in that folder are accessible by all Windows programs - including Broderbund programs. However, older versions of Print Shop and PrintMaster are designed to use ONLY *.ttf fonts . So, the only fonts that those Broderbund programs can access in the C:\Windows\Fonts folder are *.ttf fonts.
NOTE: Since both Print Shop 2.0 & 3.0 and PrintMaster 2.0, 2011 and 2012 do not access fonts from Broderbund's Core Fonts folder, the following information does not apply to those versions of Print Shop and Printmaster.
Older versions of Print Shop and PrintMaster install fonts in the C:\Program Files\Common Files\Broderbund\Core Fonts folder. The fonts installed in that folder are accessible ONLY in Broderbund programs and are NOT accessible in other Windows programs.
Some newer versions of Print Shop and PrintMaster install shortcuts for some (but not all) Broderbund fonts in the C:\Windows\Fonts folder. When shortcuts for Broderbund fonts are installed in the C:\Windows\Fonts folder, those fonts will be accessible in all Windows programs.
For all other Broderbund fonts - which don't have a shortcut in the C:\Windows\Fonts folder - the most efficient way to use those fonts in other Windows programs would be to manually install those fonts in the C:\Windows\Fonts folder.
To install Broderbund fonts into the C:\Windows\Fonts folder, do this:
WinXP & WinVista:
1. Open the C:\Windows\Fonts folder (either by going to Control Panel then clicking on 'Fonts' or by opening Windows Explorer then selecting the C:\Windows\Fonts folder)
2. When the Fonts window opens, click on 'File' in the menubar then click on 'Install New Font' in the menu that drops down.
3. When the Add Fonts window opens, click in the box next to 'Copy fonts to Font folder' (to remove the checkmark).
NOTE: When the checkmark is removed from the box next to 'Copy fonts to Font folder', the end result will be one font file in the C:\Program Files\Common Files\Broderbund\Core Fonts folder and a shortcut to that font file in the C:\Windows\Fonts folder. If the checkmark is not removed, you will end up with two identical font files - one in the C:\Program Files\Common Files\Broderbund\Core Fonts folder and one in the C:\Windows\Fonts folder. Since it's not absolutely necessary to have font files in both folders, you can save some hard drive space by making sure that the checkmark is removed from the box next to 'Copy fonts to Font folder'.
4. Using the Folders: box on the bottom left side of the Add Fonts window, navigate to the C:\Program Files\Common Files\Broderbund\Core Fonts folder. Then, double-click on the Core Fonts folder.
6. After the font names are displayed, click on the name of the font you want to install, then click on OK. After the font is installed, it should appear in the fonts lists for all of your installed software.
If you don't mind having two identical font files on your hard drive, you can install Broderbund fonts by simply copying the font file from the C:\Program Files\Common Files\Broderbund\Core Fonts folder to the C:\Windows\Fonts folder.
Windows 7:
Either simply copy the font file to the C:\Windows\Fonts folder or right click on the font file then select 'Install' from the menu that drops down.
Win98 or WinME:
WARNING: If you are using Win98 or WinME, you will want to be sure to NOT have more than 750 fonts installed in the C:\Windows\Fonts folder - because more than 750 installed fonts on Win98 or WinME can cause a multitude of problems.
How to convert pdf to pmx file
I wonder whether there are any differences between the pdf converter I am testing these days and the one you mentioned above?
How to Convert PDF to Image in NET
*.sig to PDF convert
Anyone has experience about the pdf to image conversion toolkit I am tetsing these days? Any suggestion will be appreciated. Thanks in advance.
Convert PDF to Image Types in NET pqScan com
I have Printmaster Platinum 15 installed in an older computer (xp) and can convert a file to PDF. I installed it in a newer one (Windows 7) and cannot convert to PDF. I get something that says "Unable...
download pdf995 onto windows 7
http://www.pdf995.com/
it will install there are two files you have to install
once installed it will look like a printer to your program and then print to the pdf995 printer and it will convert whatever you print into a pdf file.
1helpful
Does not read .sig files
Small text file that can be automatically attached to the end of e-mail messages; usually includes the sender's name and e-mail address; in work-related e-mails, the signature may also include the name of the person's company, the person's title, and contact phone numbers; some people choose to include a quote or Bible verse in their e-mail signature.
Most e-mail programs support multiple signature files; they can usually be selected from within the create new message window. Program(s) that open sig files mac.gif Mac OS tri.gif QUALCOMM Eudora Pro
windows.gif Windows tri.gif QUALCOMM Eudora Pro
tri.gif Microsoft Outlook
tri.gif Microsoft Outlook Express
Broderbund Sign File Popularity 3.gif Average Category Image Files File Description Image format used for signs and posters created with Broderbund graphics software, such as PrintMaster and The Print Shop; can be opened with the program that created the file and possibly with other Broderbund programs or versions, but compatibility is not guaranteed. Program(s) that open sig files mac.gif Mac OS tri.gif Broderbund The Print Shop
windows.gif Windows tri.gif Broderbund The Print Shop or PrintMaster
I have the Printmaster Platinum Version17 , I cannot save to pdf files?
As a work around untill we can figure this issue out. http://www.acrosoftware.com/Products/CutePDF/writer.asp
This is a FREE PDF Print to file program.
At the top left of the page the are links to the PDF Creator and the Required GPL Ghostscript 8. The program will not function without it. Both programs work with x64 Vista. Read the website for the other benifits or the program.
3helpful
2answers
Cant save to pdf in printmaster gold 17
found the fix for printmaster 18 broderbund pdf saving problems...
1-close all open programs and return to desktop.
2-click START and choose CONTROL PANEL
3-click PRINTER
4-right click on BRODERBUND PDF CREATER, then select PROPERTIES (the broderbund PDF creater properties window will open)
5-click the PORTS tab, then select ADD PORT button. (the printer ports window will open)
6-click NEW PORT, then enter PMPDF in the ENTER A PORT NAME window, then click OK
7-click CLOSE at the PRINTER PORTS window. you will now be looking at the broderbund PDF creater properties window
8-a check mark will be located next to the new PMPDF printer port. click APPLY. the broderbund pdf creator will now be located next to the new port. click OK.
9-exit all windows and restart the computer. once the computer restarts, you can save your project as a pdf file.
1helpful
1. In Tools/Options/General Options, check the box beside "Optimal Printing Resolution".
2. Go to File/Printer Setup/Printer Setup.
3. Under "Name" select Broderbund PDF Converter v2.10d
4. Next, go to File/Professional Printing.
5. Select "Save As PDF".
6. At the next screen, type the name of the PDF file you want to save in "Project Name".
7. Under "PDF Resolution", select 600 dpi.
8. Click on "Save As". In the next window, browse to the folder in which you want to save the file (for example: My Documents).
9. Click on the "Save" button.
10. PrintMaster will save the PDF file to the folder you selected.
11. Open the file in Adobe Acrobat to make sure all the elements and pages are there and that it looks as expected.
Top Broderbund Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
