EnGenius EOC-3220 (EOC3220) Logo
Anonymous Posted on Aug 22, 2011
I have a Engenius 3220, can't access on 192.168.1.1, I was change the firmware and can't connect now... are another IP to access, I try whit DDRT tool but not can see the IP.-
  • Anonymous Oct 20, 2011
    The problem was before I was make a bad firmware upload.-
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 16, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
575
Points
Try the program Belarc Advisor. It worked for me. I had the same problem when I updated the firmware of my EnGenius ERB9250 Extender. Once Belarc has displayed everything it has discovered about your computer, scroll down to the area labeled Network Map. There you will find your EnGenius 3220's IP.
  • 1 more comment
    I've run the Belarc, but can't find the AP
  • Anonymous Oct 21, 2011
    Here is the relevant section of Belarc Advisor showing the network IPs.
    I've reset many times until the RTL 8186 was in ftp mode, (192.168.1.6) then y put the firmware with the Vista tftp tool.. it's work finelly.. TK'S
Level 3:
  • EnGenius Master 7,733 Answers
  • Posted on Oct 17, 2011
EnGenius Master
Level 3:
Answers
7733
Questions
0
Helped
1864946
Points
21487
How to reset the device?
Locate the reset button next to the CAT5 (RJ45) connection. Press and hold the reset button for 10 seconds and then let go. You should see your 10/100 LAN connection at your computer go away and then come back. That will confirm a reset has occurred. The unit settings should all be back to default including its IP address of 192.168.1.1.
    I've made this... several times.-
Mac Laptop cannot access internet via the Engenius EAP350 wireless AP
Jason,
What does the logs say over EAP350, are the cards on Macs properly getting associated with EAP350? What happens if you put static IP?
Also check for the latest firmware for EAP350 which addresses this issue.
Regards
2answers
EOC-3220 connects but no internet access
What are you using for Internet connects? do you have the Access point connected to a Router. or is it connected to the Cable or DSL modem. I will need more information to complete this. If you have a router is is set to give an IP address or do you have a static IP? If it is set to give a Dynamic ip change the access point to recieve ip address from router and same with computer. If your connected directly to the Modem with the access point and you only have one IP address it will be used by the access point and not allow the computer to connect.
for more help please provide your internet (DSL, T1, CABLE) if you have router,  how it provides IP, and how access point is connected to it.
Problem loging into the web page of EnGenius EAP-3660 Access Point
I thought the default IP was 192.168.0.1. That is where mine went when I pressed the reset button.
Pls i was trying to fix my engenius radio, and i mistakenly imputes wrong ip from 192.168.1.1 to 172.16.7.1 after rebooting, i cant even access the log on page from internet xplorer again wit boths...
The wireless adapter in your ENGENIUS has connected to a wireless-router.
Depending on which router that has responded, the IP-address assigned by the router could be:
* 192.168.0.xxx
* 192.168.1.yyy
* 192.168.2.zzz
* 172.16.aaa.bbb
If the router to which the ENGENIUS has "associated" has _NO_ Internet connection, then you won't be able to access any web-sites.
You need to "dis-associate" from that router, and "associate" to a different router (one that DOES have an Internet connection).
2answers
I can only connect one laptop to the internet. When i turn on the second one it makes the first laptop loose its connection with the internet. My service provider says its the router. Can u help?
Hi! I think you have an IP conflict on your laptops. Do this: goto control panel and open the network section and put a fixed IP address for both the laptops, lats say: LapTop1: IP: 192.168.0.10 LapTop2: IP: 192.168.0.20
And put a DNS number in the same section where you put the IP numbers. The DNS number is the IP number of your router. WARNING! your router IP address must be in the same region as your laptops. Lats say Router IP: 192.168.0.1 than your DNS address on your laptops are 192.168.0.1.
Check in the router of some security restriction like how many users can be connected through WiFi connection, check for firewall enabled or disabled, if enabled try disable it and try to connect now.
I hope this solution will help to solve your problem.
I set up the Engenius EAP as a repeater and can connect to it with my lpatop and Iphone. When I try to connect another laptop I have excelletnt connectivity reception, but Internet Explorer cannot display...
Signal is only one part of the complete connectivity problem. Your lack of connectivity is almost certainly due to some other component, such as your second laptop having an incompatible static IP address specified, or no DNS servers specified.
First, ensure your PC is configured for a dynamic IP address. Once you have acquired good signal and connected, check to see that you have received a dynamic IP address. If that works, open IE and type in the numeric IP address if your EPA repeater. If you get a response, the problem is not your wireless connection or local IP address. Now type in the IP address 74.125.19.103 . If you get a response, your problem is that you have no DNS servers specified.
I cant reset my senao eoc3610
1 ) Check if IP address is the correct address of your Gateway.
Check if you can ping.
Be sure you have your Java enabled
Some router requires a specific Browser (IE6 or IE7) and cannot respond to different browser.
Be sure to remove any Java protection from your Browser.
Check with user manual if IP address requires also a specific port number ( 8080 or other).
Be sure to Connect Router using Lan cable
2) Change your PC IP setting to same subnet as your router
Control Panel / Network settings / properties of TCP/IP define an IP address and a subnet mask compatible with Router as gateway.
3) If you are not sure of Router IP address use reset button on router back to factory default; use this to configure router.
After a windy day lost wireless connection
For a new unit disconnect the eoc from the network and connect directly (through POE injector of course) to your laptop/pc.  then in network connections setup your lan port TCP/IP settings as follows.  ip 192.168.1.10 subnet mask 255.255.255.0 then gateway 192.168.1.1
point your browser to 192.168.1.1 or 192.168.1.2 (one if it is in AP mode and the other address works if it is in bridge mode).
When configuring, I assign it an new static IP outside of the DHCP assignment range.
To see how it is setup afterwords you can use hyperterminal with a null modem cable to view the current config.  instructions on the engeniustech.com support page.
SENAO EOC 3220 CONNECTIVITY PROBLEM
hello!
-- try to change wireless channel on your access point
-- try to enable wireless security on your wireless network
-- try to assign static ip address on your wireless computer
Top EnGenius Computers & Internet Experts
john h
Krzysztof Tomasz
Level 1 Expert
Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
