Haier HDN655E Dehumidifier Logo
Posted on Aug 22, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I just purchaed a DE Series Dehumidifier. The instructions say to press the arrows keys to adjust the humidistat, but whenever I push the arrows the display reads "on". So I don't know what it is set to and would like to know how to adjust my humidistat
Anonymous
Level 3:
Brigadier General:
  • Master 4,736 Answers
  • Posted on Aug 22, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
4736
Questions
0
Helped
2103378
Points
14643
It is not abnormal for ON to show up when you first push the arrow up or arrow down button. If you want to lower the humidity press the arrow down button again, once the ON lights up. The lower you take the percentage the more humidity will be removed.
Hope this helps you and thanks for choosing FixYa.
1helpful
Compressor Works for a while Only On Initial Plug-in
If your machine is equipped with a humidistat it could be faulty and not sensing the humidity level accurately.
Our Challenge 4151319 Dehumidifier has ceased to collect water. The fan operates perfectly. Can I get it serviced in Devon?
First, make sure the humidistat isn't set too high by adjusting it to the lowest humidity setting and running it again.
Next, test the dehumidifier by placing it in a closed bathroom with a hot shower running. If you don't see water collecting in the unit after several minutes, turn the unit off and clean all dehumidifier filters and coils. If, after adjusting the settings and cleaning the unit, you still don't see water collecting, you may have a refrigeration issue.
This situation will have to be addressed by a qualified technician.
Good luck
Dehumidifier is running but, no water is being extracted from the air.
First, make sure the humidistat isn't set too high by adjusting it to the lowest humidity setting and running it again. Next, test the dehumidifier by placing it in a closed bathroom with a hot shower running. If you don't see water collecting in the unit after several minutes, turn the unit off and clean all dehumidifier filters and coils. If, after adjusting the settings and cleaning the unit, you still don't see water collecting, you may have a refrigeration issue. This situation will have to be addressed by a qualified technician.
Take care.
The Dehumidifier is not collecting water. How do you get this fixed?
Good luck.
2helpful
I have Delonghi DE500P dehumidifier was running but doesn't pump water. how can i fix it.
Good luck
1helpful
Runs and allows you to adjust settings, but no water ever fills bucket
Take care.
1helpful
Won't draw moisture
Good luck.
2helpful
My dehumidifier has not, does not collect any water. HELP !
Take care.
1helpful
I have a Comfort-Aire BHD-301 dehumidifier that runs but does not collect water. What should I do?
Take care.
A Question
You can test the humidistat fairly easily, using a volt-ohm meter. Just set the meter to RX1 scale and attach its leads to the humidistat's terminals. Rotate the humidistat's knob as far as it will turn in both directions. If the volt-ohm meter registers zero ohms through only part of the humidistat dial's range, the humidistat is working. If it registers zero through the entire range, it's broken and must be replaced. Dehumidifier Overflow Cutoff Switch Test- Using a volt-ohm meter, you can tell if the overflow switch works or not. Clip the leads to the terminals on the switch. Depress the bar or trip lever on the switch. If the meter's needle doesn't show continuity and no continuity as the switch is clicked back and forth, the switch is probably faulty and will need replacement.
Top Haier Dehumidifiers Experts
ZJ Limited
ZJ Limited
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
