You could have a broken pipe on the filler or the seal has gone on the drum you would need to have a look, either way they are easy to fix or replace. drain pipe can leak if the pipe has come off the pump also check this but you will need to remove the case to get to look, always unplug the washer before touching any screws, remove case and look at the pipes and make sure they are seated in the right place.
SOURCE: Hotpoint Ultima WT965 - Water gushing out from door and soap drawer
you have a blocked filter, unplug from mains, take off back panel you will see a black sump hose coming from the tub to the pump, tilt the machine forward and put a dish or bowl under sump unscrew clamp and pull off slowly to release any water in the drum. You will find a blockage, also what appears to be a ping pong ball dont throw away it is meant to be there.
SOURCE: water gush in power drawer
When water comes out of the powder drawer on spin I think you will finf that the filter is blocked. This sits in the rubber pipe between the drum and the pump. I had the same problem and a half hour with the back off fixed it. A colour catcher was blocking the filter.
SOURCE: how do i fit a drive belt on a hotpoint tumble drier
Hi, To fit the belt to your dryer you will need to remove the top of the appliance by removing the screws at the rear. Pull of the timer/control knob. Look inside the top of the t/dryer behind the control panel you will see little plastic stems which are attached to the facia panel. You need to knock these out to remove the facia. Once this is off then you can remove the the top 3 screws and the bottom 3 screws the front panel will now come off for you to place the belt on the drum and over the motor spindle. Becareful as the t/dryer will be very loose and will twist. it is easier to lay the appilance down on its back to stop everything falling about. Now you can put it back together in the reverse order....
Good luck.............
SOURCE: change drum bearing on hotpint aquarius wf540 .
This is usually a very hard thing to do,, due to the fact that you have to separate the plastic drum housing to reveal the metal drum, and than you need to free it from the back portion of the plastic drum housing
in this case i would remove the pump (bottom, back, right hand side)
this is easy cleaned.... then remove dispenser and dropdown pipe and clean out clogs
