The tv main logic board known as a tv Tuner signal board it is the causes and the problems.The tv main logic board,the tv Tuner signal board it is shorted and not taking in and sustance power from the tv power supply board anymore that why tv Power and OPC LED lights indication are flashing together.This main logic tv Tuner signal board that the board where that take in the tv incomming broadcasting signal wire plug into it.U must replaced the main logic tv Tuner signal bard to fixed this problems.If U have some mechanicals skills like take things aparts and putting it back together again?Yes,tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish main logic tv Tuner signal board for the replacement.Tries tv unplug,replug it back about an hour later.Tv might work again for awhile though,but to fixed this problems for good the main logic tv Tuner signal board must have to be replace.
Hi Chi Chu. I just inherited an Sharp lc-c5277un that turns off within 5-15 seconds of power on. No additional blinking lights, no OPC, nothing. It then will power cycle and turn on again and then do the same. I pulled the back panel off and realized that the Antenna hookup has been ripped out of the Main Board. Normally a dead port wouldn't kill something, but based on what you said it sounds like since this is the TV Tuner board it possibly is just causing the TV to turn on/off. Is there any way to verify this before I go and try to source a replacement TV Tuner board?
