there are two kinds of white screen in phone,
the first one is because of damage LCD (glass screen) ,
defective display driver (small chips that makes the display works)
and the other one is corrupted software...in damage lcd the phone will detected
by computer because its software is still working...so ,
the problem of your phone am sure is the second one ,
corrupted software....your phone needs to reprogram,and
need to go to the model of the phones care center to fix you problem...
i hope ,i will help you ,thanks
Since everything works fine, just the display problem, with this, there is nothing wrong with your screen, the problem is
from the flex that connects your screen to the phone's main board. This
flex must have worn out that's why your screen is not displaying any
picture.
The problem is common with flip and slide phones. The
flex gets worn out as a result of constant opening and close of the
flip or slide phone.
I would urge you to replace the flex and I
am assuring you that your screen will display picture again. You might
also be lucky to find out that the flex is not well fix, that is, it
may have loosed contact.
If you cannot change the flex yourself,
maybe you should take the phone to a local repairer within your
vicinity, so that the flex can be fixed/replaced.
No I was asking how I can do a hard reset without going through the screen menus.
