SOURCE: Kenmore dishwasher - soap not dispensing
that sounds crazy but hears some suggestions you must have real hard water for that tab- not to dissolve hear is a crazy question is the water coming in to the d/w hot enough or even hot at all i had cases where i found that the d/w was hooked up to cold water
SOURCE: 587 Doesn't work well
AS ABOVE SUGESTION ...PROBUBLY NOT GETTING ENOUGH WATER. NOT LIKELY THE FAULT OF THE DISHWASHER PROBUBLY SEDIMENT FROM THE WATER PLUGED THE INLET SCREEN OF THE FILL VALVE. MANY TIMES THE MOVING OF A FLEXIBLE PLUMBING LINE BRAKES LOOSE ANY SEDIMENT AND DEPOSIT DURING THE INSTALATION OF A NEW DISHWASHER WHICH IS WHY MOST ADVISE REPACING THIS SMALL FLEXIBLE LINE WHEN INSTALLING A NEW DISHWASHER. YOU WILL HAVE TO DIS ASSEMBLE VALVE TO CLEAN SCREEN ...IF YOU BOUGHT THE PROTECTION AGREEMENT OR HAD SEARS INSTALL IT THEY SHOULD COVER A SERVICE CALL TO CLEAN THE VALVE.
SOURCE: Kenmore dishwasher series #168790 not cleaing dishes
Hiya,
Please clean filter in the bottom of the machine.
Even can clean out the pump. than start a wash empty and as soon as it has filled up put 3 cups of vinegar in the machine. Let it run on hot.
this should fix the problem
Also please take out the arms and make sure all the holes are not obstructed.
This is a simple way of cleaning but effective
SOURCE: bottom spray arm not rotating
The arm usually will stop rotateing because there is a obstuction in the arm itself you will need to remove the arm normally unclips (older machine used to scew off)When you have the arm out check all hole top and bottom and open any that are blocked rinse out arm and replace give it a wash and see if there is any improovement,let me know.
Thanks
SOURCE: Kenmore dishwasher does not wash completely
I had the same problem. I switched to a gel dishwashing liquid and added about 1/2 cup of white vinegar to each wash cycle. (Just pour the vinegar in a cup, put it in the dishwasher and let the water fill the cup and disperse the vinegar.) Gradually you can reduce the amount of vinegar that you use. Worked for me, hope it does the same for you.
Hi
If you
are noticing that the dishes are not clean, then there are a few things to
check for. Check the soap powder if it's kept in a dry environment. Also try
replacing the powder with something like a gel or liquid. Next thing to check
for is the water pressure and fill valve. Check if the water is filling in and
the spray arms are throwing the water with enough pressure. Try and listen to
the sound if you hear a proper spraying action sound.
If it
seems as a low water pressure then check the fill valve. Now, check if
dishwasher is draining the water or not. While the dishwasher is working check
whether the dishwasher is draining and there is not much left out water after
the cycle is complete. Try cleaning the spray arm with a soft brush. The water
temperature plays a major role in cleaning of dishes. The temp should be
between 125 and 150 F for dishwasher to clean the dishes.
Hope
this helps... Please post back if you need more information.
Daniel
