Linksys Wireless-G WRT54G Router Logo
Posted on Sep 08, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
RE: NO ACCESS TO MICROSOFT SITES FROM ADSL/MODEM ROUTER OVISLINK EVO-DSL11
Dear all
I am having a problem with an adsl modem router namely ovislink EVO-DSL11 where am not able to connect to microsoft sites for e.g. microsoft.com or even msn.com and some other sites.
I have disable all the firewalls but still same problem.
i have found a solution but I dont think its the appropriate one, I mean i have created a folder named MTU in the REGISTRY of the windows. then it works but I have to do that on all the computers. If you can help me out to solve that problem.
thanking you all in advance
Anonymous
Level 2:
Scholar:
  • Expert 65 Answers
  • Posted on Sep 09, 2008
Anonymous
Expert
Level 2:
Scholar:
Answers
65
Questions
0
Helped
25285
Points
125
If your modem/router has a setup page, you may configure the MTU on it instead of configuring it on each computer. The modem/router's setup page can be accessed using the address 192.168.1.1 on the Internet Explorer's address bar or you may follow these steps.
1) Connect to the website integrated router by typing its IP address local (default: 192.168.1.1).
2) In the left menu, click on Show advanced Settings.
3) In section Hotel, please click WAN.
4) Please set the following parameters:
-- MRU = 1400
-- MTU = 1400
-- MSS = 1360
5) Click on Submit.
6) Click the Save Setting and Reboot and if necessary on Submit.
1helpful
What happen when a adsl line work with a phone but not with a router
The phone line does two jobs. Voice phone which is what it was originally used for and ADSL modem which works at a high audio frequency.
Somewhere between the phone socket and the modem should be a filter splitter. One part goes to the phone and the other to the router. Make sure you have that.
The modem will have a power light and several additional lights. Assuming the power light is on we are interested in two of them; The ADSL light and the Internet light. When you switch the modem on you should first see the power light flash then go solid. Then the ADSL light will flash and then this should go solid. If this light does not come on then you have not plugged the phone wire in properly. If this light just keeps flashing slowly then the modem can't see an ADSL signal on the phone line. If you have a spare router you could try it and see if the ADSL light goes solid on that.
If the ADSL light is fine then the modem has locked onto the signal on the phone line, sync'ed. If not then this is the problem you must solve. Ask your ISP if service is set on your line.
The next light is the Internet light, this maybe a symbol like an i or a world. This light will begin flashing then go solid. It will flash with Internet traffic. This means you have Internet, as far as the modem is concerned. If this light does not stay on then your ADSL account name and password maybe wrong. You can correct this but that's a different question you need to ask.
1helpful
D-Link DSL-2750U N300 ADSL Modem Wireless Router configuration with Hathway
YES THATS TRUE. TO CONFIGURE THE ROUTER. NEED THE PPPOE USERNAME AND PASSWORD FROM THE INTERNET SERVICE PROVIDER. VPI AND VCI SETTINGS.
..THEN ACCESS THE ROUTER PAGE
..GO TO ADVANCE SETUP PAGE.
..THEN LAYER2 INTERFACE
..CLICK ADD
..CONFIGURE THE SETTINGS.
..POWER CYCLE THE NETWORK.
1helpful
Sitecom WL-342 Wireless Router won't access internet.
Make sure there is a network cable going from your ADSL modem into the WAN connection of the router.
If the ADSL modem is wireless, then it is also a router in whihc case you will want to bypass the WL-342 all together.
Thanks,
Pat
3helpful
Lost user name and password for configuration manager
You ADSL Modem's default username is admin and password is zoomadsl, If you have changed before you can reset the the device so default username and password will work. for further information you can check link below
http://www.zoom.com/techsupport/adsl/adsl_x6.shtml
HOW CAN I CONECT NETGAR ROUTER TO NTL MODEM
I want to tell you that this router is a ADSL router and it will only work with the adsl line or you can say through phone line. You required to connect adsl filter in order to use this router. This router will not work if you are using the with any kind of modem. Beacause this router is already have inbuilt modem as well as it will performs all functions for the router. So with this router you dont required any other modem. But still if you want to use this router. The only ways is make it as a access point so that you can use this router as a access point and it will broadcast the signals to your wireless computers.
I believe this information will help you to resolve your query.
Thanks & Regards
Jaspreet Singh Saini
2helpful
Adsl led is not glowing 802C D-link
when the adsl is not blinking that means your phone line is having problem plz ask your phone line provider to check the line.
ADSL light flashing!
what is used this router it is a adsl router or only router if this is only router then you have to connect your adsl modem then only its work properly .
USB Modem V ADSL Router/Modem
Unplug the plug (from phoneline) on back of USB modem, plug into Zoom router. Plug one end of an ethernet cable into router and one end into your PC. Type http://10.0.0.2 into a web browser (eg. Firefox or Internet explorer) username/password is admin/zoomadsl go to basic setup and input your ISP username and password (the one given to you by your internet provider) under PPP. Click configure my connection. Save changes and then write to flash (both buttons on bottom of page)
Zoom router
Have you tried configuring the ADSL modem router for the internet connection?
Its possible that since you have changed the ADSL modem router, you may have to configure the ADSL modem router for it to work fine. The configuration depends on what Internet provider you have but you may try these steps for now:
1. Make sure the connections are correct. Connect the computer to the LAN port and the ADSL line to the port assigned for that behind the device.
2. Launch an Internet browser and access http://10.0.0.2 and press enter. If a dialog box appears, set the user name as admin and password as zoomadsl and press enter.
3. On the basic setup page of the ADSL router, set the appropriate encapsulation and other settings based on the settings of your provider. If you do not know the settings for your provider, there is a table specified on the user guide for the ADSL router. Here is the link: http://zoom.com/documentation/adsl/5590_UserGuide_EngD.pdf
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
