daniel the electric hob is schott ceran not sure of serial number will get back to with thanks clive jonesdaniel the electric hob is schott ceran not sure of serial number will get back to with thanks clive jones
You can't post conmments that contain an email address.
F1 or I Error indicates a bad control board and the control board (electronic control) should be replaced to solve this issue. Hope this helps...please post back for further assistance.
Daniel
helps...please post back for further assistance. Daniel
If your Lamona electric oven is stuck in demo mode and the manual does not provide any information on how to disable it, you may try the following steps:
Unplug the oven from the power outlet for a few minutes and then plug it back in. This may reset the oven and remove the demo mode.
Press and hold the "-" button for about 10 seconds. This may disable the demo mode and activate the oven.
If the above steps do not work, try pressing and holding the "Function" button for about 5 seconds. This may activate or deactivate the demo mode.
If none of the above steps work, contact the manufacturer or a professional technician for assistance.
These codes mean that the oven's electronic control hasdetected a condition it needs to check which mean error. When you see a code,follow these steps to solve the problem:
Press "Stop/Clear" to clear the display and stop the beeping.
Reprogram the oven.
If the code still displays, turn off the power to the oven at your breaker box and wait five minutes before turning it back on.
turn on the hob, press right hand front corner and minus button at the same time, this will unlock the hob (Child Lock) to cancel the child lock press the minus button again immediately after unlocking.
Normal use is restored.
When you turn on the hobs main power, press the the rear left hand element pad at the same time and the lock will come off.
press the centre minus button and the bottom right plus button at the same time it will work if not keep trying
You have to hold down the centre sensor button with the minus on and the sensor which turns on the bottom right ring immediatley after turning the hob on. It should unlock, then press the minus again the hob switchs off when you now switch on there will be no lock
please call Scholtès free on 08001 58 55 00 and we'll try and get you some technical help for that. It would help us out if you had your hob's model number to hand if possible, if not we'll try and find it for you.
Try unplugging it, wait 60 seconds, and plug back in. Or press the HELP button if there is one, press the number "1", and press STOP. That works on my Sharp microwave.
