To remove the knob, there should be a small hex key or allen screw on the side of the knob. Just loosen the screw. You don't have to remove it.
To tighten the nut properly, you may have to remove the back panel of the bass and hold the potentiometer from the other side. If allowed to turn too much, it could mess up the wiring.
It is NOT clear what you are trying to do... HOWEVER if you are attempting to extend a bass potentiometer remotely, you CANNOT use the four wire flat telephone line as it is unshielded and you will pick up hum.
the bass nob must have worn out, that's why it cannot stay firm when you press it in.
Get something tiny like a pin, press the bass knob in, and at the same time fix in the tiny object by the side of the knob, to hold the bass knob firm, so that it will not pop out when you let go off it.
I'm wanting to know the same thing... But be careful on the pin out of the control you get.
I have an audiobahn 2300HCQ amp... Before I had the 1800. The 1800 came with a remote with 6pin remote cord. I got the 2300 used and did not get a control for it. The plug on the 2300 is a 4 pin plug... I can't figure out how to cross it over correctly to get the 1800 remote to work on the 2300.
I have tools to crimp an end... Just can't figure out the color pin out.
Not all controls are the same. Manufacturers use various schemes to control the level of the audio. If you use a control that's wired improperly, you risk damaging your amp.
i don't think you'll have any problems if the hook up will fit. i myself have a lighting audio bass knob hooked up to a jensen amp and haven't had any problems from that
