Hi there.
To repair this error, download and install each of the software
tools listed below. These have been specifically designed to help
repair this error;
Sometimes
Error 1359 - Error Code 0x54F can be caused by spyware or virus
infections, so it's wise to run a removal program like the one below,
to remove any spyware infections.
Let me know if you need further assistance.
To begin the installation, once you've clicked on the a link above,
a new window should appear with several options on it. Click Open or Run this program from its current location. Or to save the download to your computer for installation at a later time, click Save or Save this program to disk.
Once installed, run each program by pressing its scan/update button. Once the checks are done, you can let the tools fix the problem.
Welcome to Fixya
The only problem that you should experience there when installing a driver if the driver is incompatible with the Windows that you are using. Are you using the driver intended for your windows OS? Please provide me the Windows operating system that you are using and i will help you find the correct driver.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
you can download the driver update from this link. The software update can only be used if you already have the Jabra Bluetooth Adapter A320s software installed.
windows vista home premium 32 bit
tried that does not work.
error code 0x54f
do i need to upgrade widcomm bluetooth software .1700 with vista update for jabra a320s to run on win vista 32bit
