Sanyo Xacti VPC-CA 9 Flash Media Camcorder Logo
Posted on Apr 23, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hello I have got camera Sanyo Xacti vpc - ca9gx. Recently i lost mic but camera still was recording but after while stop working. On the top is red light flashing but it is not starting. I have open the body of camera and probably found a problem. There is black tape conecting body with lcd and is very tight so when screen was moving this tape broke. This is my idea but maybe You will have different solution. If this is only this thing I can replace this tape but very hard to find in Poland. If You give me an answer what is wrong or where I can buy this part I wll appriciate.
Pieter Vleeshouwers
Level 3:
  • Sanyo Master 2,029 Answers
  • Posted on Apr 23, 2017
Pieter Vleeshouwers
Sanyo Master
Level 3:
Answers
2029
Questions
0
Helped
4113778
Points
7389
Think you have it about thin sheets like fcc flatcontactcable that can about problems with sun heat build up inside there are special hotmelt repairs something like this kind of fcc without tools very difficult . hope you can something do with it knowing that Sanyo was become a part of PANASONIC in 2008
How to repair Flex cable Flexible PCB type flat copper ribbon cable Sanyo VPC CA9 Xacti Camcorder 720p Quick Manual
1 Related Answer
Anonymous
  • 3 Answers
  • Posted on Apr 09, 2010
SOURCE: Sanyo Xacti VPC-E1W dispay is black, no image
Is the camera on and does it have batteris fully or half way charged?
Auto focus or any focus not working on Xacti VPC-CG20
Hello
See SM for Your cameras - http://elektrotanya.com/?q=showresult&what=sanyo%20VPC-CG20&kategoria=&kat2=all
You have problem in Zoom:
1. Focus motor
2. Focus drive mechanism
If You not work with repair cameras - not touch
And - not remove the matrix from the lens - you will lose all focus adjustment.
Screen of my cam (Sanyo Xacti VPC A5) has lost its visual after fell down from table..
Cameras do not fair very well from even slight impacts, it will need to be looked at by repair shop.
3helpful
Instruction manual
Hello. By accessing this LINK you will be able to view the owner's manual for your Sanyo Xacti VPC CG20.
I inform you that the link above contains a .pdf file.
Also available for VPC-CG20EX / VPC-CG20 / VPC-CG20GX / VPC-CG20PX / VPC-CG20TA
I hope I helped you!
If you have any other questions, please leave a reply!
Thank you for using FixYa!
1helpful
Well i have a Sanyo J1 Xacti Digital camera and i lost the CD with the software to download the pictures from camera to Computer. Is there any site where i can get download it? Thanks
Try Sanyo.com - look for support button.
Most newer computers with newer operating systems will detect a camera/camcorder when connected to USB. Have you tried it without the disk?
I have an older Xacti that records to SD card. You can use a flash card reader to transfer files without Sanyo software.
Have lost manual to use Sanyo Xacti VPC-TH1
Please check this link :
www.camera.manualsonline.com/ex/thread/view/idThread/???1645152
www.commentcamarche.net/guide/???1211529-sanyo-xacti-vpc-ca9
My sanyo vpc 51285 doesnt record any sound when i go to take a video, is it supposed to be like that or is it messed up???
Hi, try to open the camera and check the 'mic' if its working or not.you need todo is desolder and resolder the connection of the mic. in that case you will know the problem.
good luck
Sanyo VPC-T700 Wire
1. write a letter to the company to send you a new one.do payment via credit or debit card or talk some way eith them about the payment technique.
1helpful
Sanyo Xacti VPC-HD1- doesn't do anything in record mode
As I have been writing on other HD1/2 problems, sometimes it can be the card which is an issue. If the card is too slow or perhaps corrupted then the device can find it difficult to record.
This and other soft faults (that are reperable by turning the power on and off, changing or reinserting the card, removing the battery) are often indicated by a flashing red recording light.
Top Sanyo Video Cameras Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Sanyo Video Camera Expert? Answer questions, earn points and help others
