Kenwood KVT-817DVD DVD/CD/MP3/WMA 7" Motorized In-dash Monitor With 5.1ch DSP Car Video Player Logo
Kenwood In-Dash Motorised Screen does not open automatically when the engine starts like it used to. It does open when you press the button. Is this a quick fix?
How do I unlock my Kenwood KDC 7009 receiver
Press the "Auto" button and "Track up" on the face of Radio at the same time until the four dash lines disappear. Enter the security code using your Kenwood remote. Press and hold the 1 then the 6 preset keys until the display shows the letter 'C'. Enter the Security code using your Remote
My Kenwood KDC-252U radio just started flashing protect on the screen.
Usually, when you see "Protect", the audio system has detected a short in the wiring. You'll have to check for loose or broken wires and missing insulation on wires that are touching anything else in the vehicle. Check all of the speaker leads from the wiring harness to the speakers.
If you can't find any wiring issues, press the reset button behind the faceplate. To take the faceplate off, press in on the upper left corner and then pull the left side away from the dash. Use a pen point or an unfolded paper clip to press the recessed button. It's below the CD slot a bit left of the center of the main unit.
If the "Protect" message continues, your CD-receiver requires service at a service center.
I hope this helps. You can see a picture of the location of the reset button on page 4 of the manual. You can find a copy of the manual from Kenwood support here: http://www.kenwood.com/cs/ce/index.php?model=KDC-252U&lang=index . The current link to the manual is http://manual.kenwood.com/files/52d6099c6e64c.pdf .
Starting up a kenwood KDC MP 149 car stereo
Try checking all of your fuses. You should have two fuse boxes, one in the engine compartment and another under the dash or in a kick panel inside of the car. There is probably a fuse on the back of the radio also.
My screen won't flip out from the dash
try pushing the little * button on the remote
How do I get the player back on?
Try code KCAR entered from the remote. 3 entry methods are detailed below.
Common Kenwood Security Codes
Many Kenwood radios are configured with the same security codes:
KCAR - This seems to be a "backdoor" to some Kenwood models.
3051 - This is the security code which is printed in the manual of many Kenwood models.
1234 - This is a security code commonly chosen by Kenwood owners.
Entering Your Kenwood Security Code
If the car battery fails or is disconnected, the Kenwood will ask for the security code.
The procedure to enter your security code differs on various models of Kenwood car stereos. Here are three of the more common procedures:
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds until the "..." display disappears.
Type 2
Press and hold the "Auto" button and "Track up" (next track button on the right) on the face of radio at the same time until the four dash lines disappear.
Type 3: Model# DPX-4020 and DPX-4030
Entering Letters on your Kenwood Remote
To enter a letter using your Kenwood remote, press a button once for the first letter, twice for the second letter, and three times for the third letter -- then press the Track Up or Next Track key to send the letter.
To send the letter 'A', press the 2 key once and then press the Track Up key. To send the letter 'B', press the 2 key twice and then press the Track up key.
Finally, when you are done entering all of the letters, press and hold the Track Up button for 3 seconds.
The key sequence to enter the security code KCAR is:
5
5
Track Up
Track Up
Track Up
7
7
Track Up
Your Kenwood should then enter tuner mode.
A Security Code Bug in some Kenwoods
There is a reported bug in the security code handling of some Kenwood stereos. In models with thie bug, the security code is stored incorrectly. The workaround is to enter the wrong security code.
In models with this bug, you have to decrement the third character of the security code by one. If your security code was 1111, you would enter your security code as 1101. If your security code was 9999, you would enter 9989.
i hope this works for you.
I have a kenwood deck and it locked i can not use it it is a kdc-mpv6022
Good Day,
KENWOOD SECURITY CODE CLEAR procedure
These codes are applicable for all Kenwood radios that do not have DVD or DVD screens located on unit.
Your radio will require one of the following procedures.
Type 1
(so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio
stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key on the remote
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key on the remote
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key on the remote
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key on the remote
The security is canceled and the set enters the TUNER mode!
The above was pulled from:
http://forum.ecoustics.com/bbs/messages/4/134366.html
Also try:
press reset use remote right after it loads press 552222777 then track forward do this with the remote open so you can use the numbers and make sure its in the audio mode the little switch on the side. prerty simple p.s. nothing will happen on the screen so dont stop pressing the code and press track forward you can now set the code to what ever 4 dig code you want in the set up screen
Also try: bypasse code of "2222"
Hope this helps
Unlock codes
Good Day,
Type 1
Type 2
Type 3
Also try:
Also try: bypasse code of "2222" Hope this helps
Need unlock code for kdc-mp825
Good Day,
Type 1
Type 2
Type 3
Also try:
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
