Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if the switch contact are not good then it will not trigger the processor to switch on the waveguides.Since the table turns without a program start and If the lights or fan work without any display or action of program being triggered to start then it can be a possible fault on the main board or the processor. Sometimes insect secretion can short the board and display panel and so the processor can work in such an erratic manner. If so clean,solder and reset the board. Thank you using Fixya
Door switches
If one of the door interlock switches
is not switching properly or there is a condensation problem on the
sensor control panel, either can cause the turntable/light/oven to
come on even though the "Starts" button has not been
depressed due to the wiring of the switches.
Check for faulty door
switches and/or contaminated actuators.
I hope that helps.
thank you solution was defective switch.
