Canon MultiPASS F60 All-In-One InkJet Printer Logo
Posted on Aug 22, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Went thru steps of waste ink refill reset several times - now alarm is still flashing telling me to check printer press resume key - did that - alarm still flashing and still tells me to check printer press resume key???
surendrababu
Level 2:
New Friend:
  • Expert 88 Answers
  • Posted on Aug 22, 2011
surendrababu
Expert
Level 2:
New Friend:
Answers
88
Questions
0
Helped
29903
Points
242
Part replacement:
- Ink cartridge
- Logic board
Ink absober is almost full
Try the Waste Ink Counter Reset Manual for "Service mode"
1. Turn off the printer. And disconnect the printer cable.
2. Press and hold the POWER button, turn on the printer.
3. The indicator (LED) should be green.
4. Press and release the RESUME button, the indicator (LED) should be orange.
5. Press and release the RESUME button again, the indicator (LED) should be green.
6. Release both buttons.
Then try another 4 steps to Reset Waste Ink Tank Counter
STEP 1:- Disconnect printer from AC power
STEP 2:- Press and HOLD the POWER button, and connect printer to AC power
STEP 3:- Release the POWER button
STEP 4:- Press the POWER button again
If you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
http://www.youtube.com/watch?v=tZlkJ-YDsZA
The waste ink absorber is almost full. what to do?
Copier Canon CLC 2620: What kind of error is E000602-0202 ?
Your error means the waste ink pads are full, its recommended you get them replaced but they should hold out for a bit. to get the printer going again you can follow these steps and reset the counter.
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button.
(DO NOT release the buttons. The Power LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and
Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light
alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4) When the Power LED lights in green, press the Resume/Cancel button the specified number of time(s)according to the function listed in the table below. (Each time the Resume/Cancel button is pressed, the Alarm and
Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4 times----Green (Power)------Waste ink counter resetting
Alarm light flashing saying check printer resume
It may be waste ink full
To reset waste tank full error in MP730.
1. Hit the "menu": Key
2. Hit "Copy" Key
3. Hit "#" Key
4. Scroll thru the menu headings until you come to "Test Mode" - 12th heading
5. Hit the "3" button- this will bring up Eprom Clear
6. Hit "0" button
7. Hit the "Stop" button
Can only try then your printer go on longer but some time the other you need to clean out the waste ink it inside the printer go to open up all.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
1helpful
Waste Ink Near Full
Try this:
Waste Ink Tank Reset
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Let me know the result.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
I CHANGED MY PIXMA INK CARTRIDGE AND HOW TO RESTART?
Here's what you can do....
METHOD #1 - Easiest, but it disables the ink tank level indicators.
1) Ignore the low ink indicator, and press the RESET BUTTON to continue printing. If you press and hold the reset button for 5+ seconds, it will disable the counter for that particular ink tank. Refill tank now.
2) Repeat as needed.
You will get a dire warning that this will void you warranty, blah blah blah. If you do need to take your printer in during warranty and you've disabled ink tank counting, simple reset the entire printer as describe below for the wate tank warning, and nobody will ever know. SAVE YOUR CANON CARTS with a bit of ink left in- your printer will need to have Canon carts installed for warranty service.
3) Eventually you may be warned that the tank is empty. Press reset as above to disable and continue printing.
If you think this entire thing is ridiculous- you are right.
Get an earlier model that takes un-chip carts, like an ip6000, or ip3000, or i960. Much simpler and you get to use the ink tank indicators after refilling.
You can reset the entire printer with the WASTE TANK reset (below) when you need to clean or change the waste tank PAD (its really not a tank) See the above instructions for the i960 and similar for other Canon printer waste tank changes.
Here's the ip4200 reset options:
button. (DO NOT release the buttons. The Power LED
selectable.)
resume/Cancel button. (DO NOT release the Power
button.)
the Power and Resume/Cancel buttons. (Each time the
time(s)
setting).
Time(s) LED indication Function Remarks
0 times Green (Power) Power off When the print head is
not installed, the carriage returns and locks in the
home position capped.
1 time Orange (Alarm) Service test print .
2 times Green (Power) EEPROM information print
3 times Orange (Alarm) EEPROM initialization
4 times Green (Power) Waste ink counter resetting
5 times Orange (Alarm) Destination settings After
entering the destination settings mode, press the
to select the destination. For detail, see
"Destination settings procedures" below.
6 times Green (Power) Print head deep cleaning
(Cleaning of both black and color)
7 times Orange (Alarm) Reserved
8 times Green (Power) CD / DVD check pattern
9 times Orange (Alarm) CD / DVD print position
correction (horizontal: X direction)
10 times Green (Power) CD / DVD print position
correction (vertical: Y direction)
11 to 13 times Orange, Green, Orange(Alarm,
Power,Alarm) Return to the menu selection
14 times Green (Power) Left margin correction Not used
in servicing.
15 times Orange (Alarm) Return to the menu selection
Changed ink jets alarm flashing number 5800 showing
Hello Saron Girl,
its not 5800 its 5B00
7 times LED Blink Waste ink absorber full [5B00] - Ink absorber (QC1-4222 / 4223 / 4224 / 4263 / 4264 / 4864 / 4221 / 4257)
<Service mode operation procedures>
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button. (DO NOT release the buttons. The LED lights in
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the
Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.)
4) When the LED lights in green, press the Resume/Cancel button the specified number of time(s)
4 times LED Green Waste ink counter resetting
5) After the function (menu) is selected, press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes,
the printer returns to the menu selection mode automatically.)
Regards,
Canon F60 Waste Ink reset
I had the same message "check printer. press resume key". I cleaned the encoder strip and reset the waste ink volume counter like 6 times and it helped. To reset the waste ink volume counter, follow the steps below. (These steps were originally posted by NerdRUs.):
Resetting the Waste Ink Volume Counter
1) Enter SERVICE MODE.---
By pressing Menu-Copy-#
2) Select TEST MODE.
3) Select [8] PRINTER TEST in TEST MODE.
4) Select 3. [EEPROM CLEAR].
5) Select 0. [INK COUNT].
6) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
Alarm light on. F80
This worked for me on an F60 and someone else on an F30. Re: Check Printer error message on Canon MultiPass by watsonk (6/7/05 11:16 PM) reply + / - It could be due to "waste tank full" alarm; you may need to reset the waste tank counter. I found a reset sequence for a MP730 printer in this website that works for F30 as well. Try: Resetting the Waste Ink Volume Counter 1) Enter SERVICE MODE.--- By pressing Menu-Copy-# 2) Select TEST MODE. 3) Select [8] PRINTER TEST in TEST MODE. 4) Select 3. [EEPROM CLEAR]. 5) Select 0. [INK COUNT]. 6) Press the [OK] key. 7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key. Skip step (6) since there is no [OK] key on F30 printers.
old marine
old marine
ZJ Limited
ZJ Limited
