Let just wait a minute. You have an inverter that is rated at 4500 watts.
This spooky. The inverter has a three phase input/three phase output? What is
the inverter going to be used for?
Next question. What type of batteries are you using and what is the
voltage/current in series or parallel? What will be the total voltage you will
producing with the batteries? What is the total current of the batteries.
Another question? What is the voltage of the 28 amps? If it going to dump 28
amps across some batteries that rated at 12 volts and 1400 amp/hrs. For 12 volt batteries with a total of 1400 amps. What you will
need approx 14 to 14 1/2 DC and with 28 amps across the batteries for charging
these batteries. The batteries will be gone in about 1 hour. Boil all the water
out of them. When a battery starts to boil it release water with hydrogen gas
(the gas is very explosive and dangerous).
You also don't have a regulation circuit to limit the amount of current
depending on the needs of the batteries. Also, you don't have a trickle charger
to keep the batteries fully charge when the batteries are idle.
You will also need DC regulated charger that will keep the voltage 2-4 volts
above you battery voltage. Without this voltage above the batteries voltage it
will not charge those batters. Batteries need to forced to except a charge
that why voltage above the source voltage. If you can check the voltage on your
car/truck with a 12 volt system. While engine is running the voltage across the battery
will be 13.8 to 14.1 volts. Now, the current limiter is the alternator it has a
regulator built into it for stabiizing voltage and current went the batteries
require more current but it limited by alternator regulator
Now, to get more current out of the alternator the regulator will supply dc
voltage to the stator of the alternator generator more current. More dc voltage
is supplied by the regulator but the dc voltages is limit to about 24 volts.
Another limiting factor is the alternator copper windings diameter---larger
diameter more current, small diameter less current. Utilities systems use big
mega watts generators. The maxi um dc voltage for these three phase generator
would like 500 to 800dc volts for peak to peak output. There is a simpler way of
doing this.
You need to rethink everything here. Also, I can help you if you supply the
needed information.
I truly wish you luck in your electrical endeavors. GB you. stewbison
Php = PkW / 0.746 (2)
or
Php = (?m U I / 1000) / 0.746
= ?m U I / 746 (2b)
where
Php = horsepower (hp)
