SOURCE: Calypso kenmore elite - problems trying to wash a load
This is usually a symptom of a bad motor control board which located under the console. I had the same problem. You can open the console by removing the three screws in the back and lifting from the rear first. The console will pop off. In addition, if you look along washer top front edge in the seam there is a retaining clip about 2 inches in from each side. Using a putty knife, push in on each clip while lifting and the top should pop up. There will be a tech sheet affixed to the front wall of the washer between the wash tub and case. This tech sheet will give you all the guidance necessary on how to perform tests to prove whether or not the motor controller is at fault, or if the pump is at fault. I believe you may have a motor controller problem, though. Another possibility is getting something caught in the drain pump reservoir. This could binding the pump. Let me know if any of this is helpful to you.
SOURCE: How to Open up a Kenmore Elite Calypso Wash Motion Washer
If this is a Calypso, there are retaining clips holding the top down in the front of the washer. You will need to look along the seam where the top meets the front panel the washer about 2 inches in from each side. Using a putty knife, insert into the seam and push straight in while lifting on the top. The retaining clips will release and the top lifts up. It may take a second set of hands to make this a little easier. When you get the top lifted up, there will be a couple of screws holding the front panel in place. Remove them and you have access to the interior of the washer. If this is not a Calypso, please post back so I can give you correct advice. I hope this helps you.
SOURCE: Error code F09/Whirlpool Duet front loading washer
"F09" is an Overflow Condition error. This is usually attributed to a malfunctioning pressure switch, loose or broken connector between the Pressure Switch, Drain Pump and Central Control Unit (CCU), or...a drain pump or drain line that has become clogged.
Since this problem occurs periodically during the wash cycle, I would check your drain pump filter for obstructions first. It could be that you have debris lodged in the pump causing it not to drain properly. To access the pump:
1. Unplug the washer.
2. Remove the lower kick panel under the door by removing the screws under the bottom edge. HINT: Placing a couple of blocks of wood under the front feet of the washer will make access much easier.
3. The drain pump is located under the wash tub in the center. HINT: If you own a shop vac, remove the drain line from the standpipe at the wall and pull a vacuum through the drain line. This will remove all residual water from the washer and make clean up later a lot less messy. Now, remove the cover on the drain pump and remove. Clean out the pump filter and check the pump impeller for obstructions.
If you do not own a shop vac, place a bunch of towels around the drain pump BEFORE you open it. There's about a gallon or so of water in the tub, drain line and pump.
Try this first, and let me know if this corrects your problem. If not, you may need to check the pressure switch and wiring. I hope this helps you.
SOURCE: Kenmore Elite Calypso wont drain
Oh the dreaded calypso pump...Seen that one a million times. Pumps get clogged pretty easily. Try to get the water out manually first. Than push the washer back and lean it against the wall so that you can access the bottom. Remove the 3 screws. Bottom panel should come off. The pump is on the right, its black. Get ready with a shop vac or alot of towels, theres gonna be a flood. There are 2 clamps on black hoses that need to be taken off so that you can slide the hoses off the pump. Next remove the 3 bolts that hold the pump in place. Next lower the pump out of the hole it sits in. Youll have to follow the wiring harness up and disconnect it. Now you can try and clen out the pump or replace it. Part # is 285990. Costs about 75.00. Hope that helps. Let me know if yiu need more help. Dave www.washermd.com
