Sony Handycam DCR-HC21 Mini DV Digital Camcorder Logo
Posted on Aug 22, 2011
My sony handycam DCR-HC21 video camera's touch screen just stopped working. How much would it cost to repair this? I believe it could be a problem with the flex cable or the lcd.
Anonymous
Level 1:
New Friend:
  • Contributor 47 Answers
  • Posted on Aug 22, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
47
Questions
0
Helped
6516
Points
62
The price depend on your country,as me charge 5000 for changing the flex if it is the flex that is faulty
3helpful
Sony handycam DCR-HC26 touch screen not working
This is usually caused by a defective LCD module or a defective flex cable that connects the LCD to the camera. I recommend replacing them both at the same time. The LCD / Touchscreen module is no longer available from Sony at an reasonable price for this Model. However, I have a limited supply of them in stock as well as an aftermarket supplier with hundreds of them.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have it repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
My handycam dcr hc21 screen wouldn't work when you touched it. i followed the directions and reset the camera. now the screen has the reset screen and i can't refigurate it. please help
Hi Alisa,
You have broken fine flex cable between your screen and board/PCB causing your touch screen ****** to work. So first of all you need to replace the cable first with new one.
Regards
My Sony Handycam DCR-HC21 touch screen stopped working.
This is usually caused by a defective LCD module or a defective flex cable that connects the LCD to the camera. I recommend replacing them both at the same time. The LCD / Touchscreen module is no longer available from Sony for this Model. However, I have a limited supply of them in stock as well as an aftermarket supplier with hundreds of them.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
I have a Sony Handycam DCR-HC32. The LCD screen has gone black. I can still touch the bottons on the black screen and they work, but I can't see anything on the display.
The most likely cause for this is a damaged or defective flexible ribbon cable that connects the LCD to the camera body and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
1helpful
Sony handycam dcr hc21 when i insert my tape the door closes but does not load into the camera. i am not getting any error code on the screen, just says that there is no tape inserted.
Tape mechanism problems can be quite complicated. This will require disassembling the camera to repair the tape mechanism and can be done fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
TOUCH SCREEN OF MY SONY HANDICAM (DCR-HC21 NTSC NOT WORKING
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
4helpful
Sony DCR-HC18e Touch screen stopped
The problem you have on your Handycam is the flex cable FP-835.
You have to open the camera and change the cable.
It´s very easy to change.
Top Sony Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
