One of the components got wet. Check the
Joystick harness for moisture and see if the circuit breaker button has
been triggered . A volt meter can be used to see where the power is
stopping at.I like to start at the Batteries (12.25 volts min. each) to function properly.
I assume there are no lights at all on the joystick assembly when you try to turn it on?
There
should be a 4 pin cable leaving the main control box that goes up to
the joystick assembly. Actually it is two cables that connect together -
a first half, then a 2nd half. Check that connection we that connect
together at the half length point - take it apart and plug it together
again. Inspect the both of these cables for damage or kinks. Trace this
cable back to the main control box, unplug it there and check for 24
volts coming out of that box again from the connector that feeds to the
joystick. If you truly only have 8 or 9 volts on this connector, then
the main control box is defective. This does not happen very often. I
only replace about 1 out of every hundred service calls.
So, weak link is always the joystick. I would recommend you to speak to him to check and replace the joystick as it seems to be a problem in your case.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
The service engineer who worked with it, is he a Jazzy Wheelchair Certified? These people at Southwest Medical can help you determine what the problem is and if there are parts that needs replacement, they will be able to tell. Here is the link to get to them http://www.southwestmedical.com/replacement-parts/pride-mobility/jazzy-1120-2000 and also here's the number to dial to talk to a live person 1-800-236-4215.
If the service engineer was not able to figure out what the problem was while he was doing hands-on troubleshooting, so we can't.
If that's the case, contact them through email, http://www.southwestmedical.com/company/... to at least determine which part needs to be replaced. No one knows Jazzy better that Jazzy experts.
We would like to know what parts of the machine are the most vulnerable to moisture. We think that the controller has dried out. We are writing from the UK by the way.
