Question about KitchenAid K45SS Classic Stand Mixer
The motor runs but the beater doesn't turn, as though the gear drive has failed. How do I take the mixer apart to check the gear drive?
  • chef neff Sep 16, 2008
    I have the same issue, you turn it on, the motor runs, but the beater doesn't move. You can check out http://www.mendingshed.com/k45map.html for a diagram and possibly order parts. I am looking into it further myself...
Http://www.fixya.com/support/t636606-kitchenaid_ksm90_stand_mixer
Kitchenaid service manuel gives step-by-step instruction on a stand mixer.
Posted on Sep 20, 2008
SOURCE:
How to replace motor in kitchenaid artisan mixer
Sounds like a worm gear problem to me, it's impossible for the motor (armature) to move far enough to not drive the gear. There are driving pins in the system from fuse gear to paddle.
1) in the fuse gear
2) inside gearbox above planetary joining shaft to bevel gear
3) through planetary and shaft
There is also one joining the little gear inside the planetary to the shaft, doubt you'd break that one though.
Jun 30, 2014 | KitchenAid KSM150PS Artisan Series Stand...
The mixer runs but the beater doesn't turn. Drive shaft?
a gear or gears. their usually plastic and will damage before the drive shaft
Feb 07, 2013 | KitchenAid K45SS Classic Stand Mixer
Beater won't turn, but motor is running.
Hi, Did you push the beater in so that it clicks. If all is good there, gear box maybe at fault or jammed. Take it to a service center for repair. If you are machanicly inclined (DIY) Take it apart and see why its not turning. Good luck.
Jun 04, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
Beaters won't turn bowl still does turn
I just took mine apart for this same issue. What i found was the plastic beater drive gears have been stripped by the motor worm gear. I am currently looking for these parts to replace them.
Dec 28, 2010 | Sunbeam 2346 Heritage MixMaster Series...
The mixer motor runs good but beaters turn slowly and will not turn when the beaters are under load. Is this a clutch, gear or what? Any ideas? Do you think it can be fixed?
I found out by marking the shaft and gears with a magic marker that the main shaft that drives the sun gear was slipping. My cure was to drill a 5/32 hole a 1/4 inch down through shaft and drive a 5/32 roll pin through it and it solved the problem. See my picture.
Nov 21, 2010 | KitchenAid KT2651X Epicurean Stand Mixer
Beaters will not move
You have probably stripped a gear in the gear housing. Here is the breakdown of the gearbox:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208212010.pdf
The newer "more improved" mixers use plastic gears and they can't take the beating, no pun intended, and fail.
The good news is that the most likely gear to fail is cheap. Here it is on amazon.com:
http://www.amazon.com/KitchenAid-W10112253-Worm-Gear/dp/B0006HLAVA
http://www.misterfixit.com
Mar 25, 2010 | KitchenAid KSM150PS Artisan Series Stand...
The motor works fine and you can hear it engage as you change it from speed to speed but the the beaters do not turn
This sound like the worm gear has failed: http://kitchenaidmixerspares.co.uk/Home/tabid/36/p/Mixer-Part---Worm-Gear-and-Bracket-240309-2/ProductID/103/CategoryID/17/Default.aspx
You will need to take the mixer apart to confirm this.
Jan 23, 2010 | KitchenAid K45SS Classic Stand Mixer
Motor runs, beater stopped rotating. Some gear sounds heard before it stopped. Beater will not turn at any speed setting.
drive gear or shear pin stripped. Common on this model. Return to repair centre. Expect to pay approx $150.00 to repair, sorry.
Sep 14, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Motor runs but beaters do not turn.
I challenge you to do-it-yourself...you can do it. Just be careful when removing it apart. I advise you to take a video or get some snap shots while you are at it. This way, if some springs snaps out, I assume that you took a picture of it already.
Usually those plastic gears are the problem. Goodluck!
Jan 13, 2009 | Sunbeam 2350 Stand Mixer
Motor runs but the beater does not move
you most likely stripped the plastic gear (Worm gear???).  This gear is designed to fail to prevent the motor from burning out under EXTREME loads (i.e. when a metal piece falls into the bowl). The plastic gear is much cheaper than a new motor.  Look around on this site to see how to get at/repair the gear.  I've found many parts on eBay.com and also PartSelect.com.
Dec 16, 2007 | KitchenAid KSM90 Ultra Power Series Stand...
KitchenAid K45SS Classic Stand Mixer Logo
113 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
CJ C
CJ C
Steve Allison
Steve Allison
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
