Hi Zsolt!
The problem can have more causes:
1. At the lower part of the machine is a kind of filter for the dirty water. It is possible it need to be cleaned, a lot of stuff can be stucked there. To get to the filter you have to remove the pannel from the front lower part.
2. The used water pump itself can be the problem, then it need to be replaced.
3. The command unit doesn't work properly so the pump for draining the used water does'n start.
It is quite simple to determine if this pump is starting or not, because it makes during running a tipical sound.
Hope it helped.
Regards,
Bogdan
