Cars & Trucks Logo
Posted on Aug 21, 2011
I need a rebuilt carborator or a rebuilt engine for my 89 jeep wrangler loredo. where can i find a good mechanic in the san fernando valley, ca?
Anonymous
Level 1:
New Friend:
  • Contributor 21 Answers
  • Posted on Sep 17, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
21
Questions
Helped
3255
Points
21
Check your local jeep forums. try Project jk. com or just search jeep forums and your location on google. Most enthuist are shade tree machs. and from experince are more than happy to help wrench on another jeep. good luck and good wheelin
89 jeep wrangler 4.2 engine how do you replace clutch slave cylinder
its on the front of the trans if the truck has a lot of rust you might want o pull out the engine other wise the trans needs to come out
How do i fix my 89 jeep wranglers float in the carberater?
Carburetor floats are adjusted (if needed) when the unit is rebuilt. This is not a normal maintenance item and it is unusual for a float to become misadjusted. Rebuild kits for carburetors are available from parts stores inexpensively, and complete instructions for all adjustments and clearances are included in the kits, as well as all the gaskets and replacement parts you might need.
1helpful
2000 Jeep Wrangler has the pistol broken according to a mechanic estimate. Car is shaking very much. I like to know how to repair this issue. Thanks
Pistol? No such animal in an engine. If you mean piston I can't see how they could tell you that without tearing the engine down. If a piston has broken usually it will damage a cylinder wall. Unless the engine is completely torn down and the cylinders are re-machined and fitted with new oversize ones, no repair is going to work.(not correctly)
If you have a bad set of rings or a bad wrist-pin, that can be done but generally that is still expensive.
Likely your best solution would be a good scrapyard engine or a rebuilt one.
Before going further though you should get a second opinion from another good shop. Since being online prevents anyone from looking at or doing the appropriate tests, that is something you need to have done.
4helpful
Need the Vacuum Diagram for a 1988 Jeep Wrangler 4.2 liter
try chiltons I got the haynes and the diagram is too hard to follow
2answers
89 jeep wrangler, starting problems
I would suspect the crank sensor, but it needs to be verified when it wont start.
89 Jeep Wrangler. Engine stalls only when I put into gear.
it might be getting to much fuel check the fuel screw
2answers
Unable to verify timing on an 89 wrangler 2.5L
are you sure you bought the right timing chain and gears? if the chilton says one things and you count differently then you could have bought the wrong set . just something to consider is all
89 jeep wrangler
Hello, We used to have this very same problem with our Mini! what you have here or havn't as the case may be is a good Earth to the Engine Starter and Battery so your cables are doing an overload job. Take an extra earth strap from engine/starter direct to battery!
Good Luck!
Paul 'W'
Onyer~EDson(:0~[><
Top Jeep Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Jeep Expert? Answer questions, earn points and help others
