First make sure you loosened the pinch bolts on the lower triple tree. I usually take a small cold chisel and insert it into the split where the pinch bolt is and tap it into the split lightly with a small hammer to spread it and open the hole just a bit. I also spray a bit of penetrating oil on the fork tube above the lower tree to lubricate the tube and help is slide out of the lower tree.
Good Luck
Steve
