Also the zoom lens motor that are the first mechanical parts after the tape was lace in. all must exactly done in a special short timing.
PANASONIC AG DVC7 SCH Service Manual free download schematics eeprom...
SOURCE: "Tape Not Inserted" on Panasonic PV-DV203 palmcorder
hai, If you are service engineer you can do this problem, Please, check the cassette IN sensing Switch. The place of the Switch is right side of the mechanism, Clean S/w with IPA solution & check. It will be ok or other wise you have replace s/w or mechanism.
SOURCE: No sound or vision playback of dv tape
From my poin of view cyliner (rotary head) have poor conection or this parts will be replace.
SOURCE: AG-DVC7
take the tape out of the camera. you don't need to put a tape in the camera if you are not recording in the camera.
SOURCE: Won't record or play anymore
You need keep the power plugged in and allow the internal battery to recharge as it may have discharged due to lack of use.
Alternativley the internal battery may need replacing by a qualified engineer. You should know if this is the problem as it usually denoted by a red flashing battery with a line striking through it.
SOURCE: Have a Panasonic AG-DVC7. When I
Tape mechanism problems can be quite complicated. This will require disassembling the camera to repair and can usually be done fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician. My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs. If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
This is usually caused by an oxidized, misaligned or defective Audio/Video drum. You can try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be serviced by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair cost low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
