NRS Hoveround MPV 5 - Used Power Wheelchair Logo
Posted on Aug 21, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you change batteries on Hoveround? - NRS Hoveround MPV 5 - Used Power Wheelchair
  • coffeetalk88 Aug 21, 2011
    Thank you....Can I move the seat out of the way? Not enough room to lift off covers.
Anonymous
Level 3:
  • Master 2,574 Answers
  • Posted on Aug 21, 2011
Anonymous
Master
Level 3:
Answers
2574
Questions
0
Helped
621361
Points
8053
Remove the black webbing strap over the battery covers by squeezing the plastic pinch clip. Remove the cover carefully so that you do not yank any of the leads. Using a wrench loosen the bolts that attach the leads to the posts, be careful if there is any corrosion that may irritate your skin. Check the fuses to make sure they are still good; if not they are regular automotive fuses that are inexpensive and can be found at any auto parts store. Remove the plastic caps or any packaging from the new battery posts and seat the batteries on the tray, connect the leads to the posts as indicated and tighten with a wrench. Turn the power chair on to make sure the connections are good and that you get power. Replace the covers, and tighten the straps. You may want to use the power chair until the battery is used up before you charge it fully for 8-12 hours; this will ensure that the battery gets FULLY cycled and any buildup inside the battery from it sitting on the shelf in the store is burned out. Make sure that you charge the power chair after a full day's use for 8-12 hours (overnight), not after every trip as overcharging can cause damage. If the power chair in not going to be used for a while, continue to charge the batteries at least one day a week to keep the batteries fluid.
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jul 07, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1889
Points
How do i get chair out of the way to change battery
3answers
Hoveround MPV5 Power Wheelchair. What batteries do I need for my MPV5 Hoveround please. I want to get the correct batteries.
Easy to fit and easy to buy.
Hoveround MPV5 Wheelchair Batteries (Replacement)
Battery Sharks https://www.batterysharks.com > mpv5_b12-35_x2
The Hoveround MPV5 wheelchair requires 2 batteries - SP12-35 NB (12 V 35 AH). Please note that you need to use all existing cables and hardware from your ...
US$110.98 · ‎In stock
12V 35Ah SLA Battery Replacement for Hoveround MPV5
Walmart https://www.walmart.com > 12V-35Ah-SLA-Battery-R...
Product details · ML35-12 SLA is a 12V 35AH Sealed Lead Acid (SLA) rechargeable maintenance free battery, Pack of 2 - UL Certified · Dimensions: 7.76 inches x ...
Assembled Product Dimensions (L x W x H): 7....
Assembled Product Weight: 48 lb "); background-repeat: repeat-x; display: inline-block; overflow: hidden; position: relative; background-size: 14px 11.4px; height: 11.4px; width: 68px;">"); background-repeat: repeat-x; display: block; background-size: 14px 11.4px; height: 11.4px; width: 62px;"> Rating: 4.3 · ‎6 reviews · ‎US$149.99 · ‎In stock
Replacement Batteries for All Hoveround Power ...
ezmobilitybattery.com https://www.ezmobilitybattery.com > hoveround-whee...
Hoveround · Hoveround MPV4 Power Wheelchair Replacement Battery (2 Batteries) · Hoveround MPV5 Power Wheelchair Replacement Battery (2 Batteries) · Hoveround ...
Hoveround MPV5 12V 35Ah Battery (2 Pack)
Raion Group https://www.raiongroup.com > hoveround-mpv5-12v-...
This Raion Power RG12350FP mobility scooter battery pack is a direct OEM replacement for your existing Hoveround MPV5 batteries (12V 35Ah).
US$119.95 · ‎In stock
How to locate and replace a fuse or fuses in a Hoveround MPV5
Here is te user manual to replace the battery where you can also find the fuse:
https://www.hoveround.com/Hoveround/media/Document-Library/how-to-install-batteries-for-mpv5-mk3-power-chair.pdf
How do you change batteries on hoveround mpv5 ?
Disconnect cables going from battery boxes to the control box. There is probably a catch that needs to be squeezed in, then pull and wigglt the connection block until it disengages. Release the straps over the battery boxes then remove batteries and covers. Lift up on the cover (you may need to push some cable back into the box) and put cover aside. Disconnect cables from batteries and attach to the new batteries. Same procedure, in reverse, gets you back to an operational MPV5.
Need to wire two new batteries in no wireing but 2 prong conection
It sounds as if you are missing your battery cable connectors. Contact Hoveround for replacement battery cables.
Can i use a lawnmower battery to replace my hoveround battery
check with hoveround to find out what battery it takes. the lawnmower battery may not have the right specs for that application.
Used hoveround power chair
mcdevito75 here, The control switch could be bad, Contact Hoverround online at Hoveround .com You can also check with any Medixal Supply store in your area.
Looking for body part orframe
Most parts must be purchased directly from Hoveround. You can mail a check or do a credit card over the phone for payment. Batteries and tires may be found locally. Some items cannot be shipped; they have to be installed by a Hoveround Tech.
Hoveround cannot be used
You need to get 2 sealed batteries, U1 type, and you will need a ****-splice connector to splice the broken wire together.
32helpful
5answers
I need an instruction manual for a Hoveround MPV 4 Power Wheelcha
Call 1-800-771-6565 extention 5000. You will need the serial number of the chair and then they will get you a manual.
Top NRS Health & Beauty Experts
ADMIN Andrew
ADMIN Andrew
Harsal Patel
Harsal Patel
Are you a NRS Health and Beauty Expert? Answer questions, earn points and help others
