SOURCE: N64 will not play on new TV and Stereo Reciever
Ok well, I don't guarantee this will work but its worth giving a shot. You know the controls like V1 2,3,4,and 5? That might be a clue because all that stuff works the stuff that's plugged into the back of the TV. They have extra cable outlets or whatever you'd like to call them in the back of the TV. So plug the n64 into the back of the TV. Then it should work someway. You might be able to figure out it from there if it still doesn't work. So don't plug it into the cable box or VCR anymore. Hope that helps.
Let me know if it works after that.
P.S. I have a n64 too, and I just got a new HDTV also. I tried to see if my n64 works on it but it doesn't so I think I might do the samething that I was just explaining
SOURCE: N64 turns on but nothing shows up on the TV
I have the same problem and from what I've read elsewhere on the net, it seems to be easily amendable by one of two solutions.
- You can re-tune a channel on your TV (not one of the main ones) and it will find the frequency for your N64 to run on
- If you had a gamecube the yellow, red and white output cables that
came with that are (apparently) compatible with both the N64 and SNES
and that way you wont have to tune your TV.
Unfortunately for me, I did not have a GC and my TV will not re-tune
due to the button on the controller not working! Good luck.
SOURCE: N64 isn't working with Vizio HDTV...
Do this, hook it up to another tv just to make sure that the N64 is workig properly. If it works on another tv then you know the system is fine. If it doesn't work on another tv then it could be that you have dirty games and you need to clean the contacts and then reinsert them into the system and get them to work.
Keep the system on a known good working tv until you can get your games to work and display properly. You can clean the games by using a damp q-tip and wiping the contacts on the bottom of the game back and forth a bunch of times, there will probably be all kinds of black that comes off.
keep on trying games untill you get one to work and display properly, then go ahead and move the tv to the one you want it to work on and test it out and it just might work then.
SOURCE: My N64 will turn on,
Well it might be a power supp;y issue or and a laser assembly failure then.
SOURCE: 64 Console: what type of tools eg: screwdrivers to open n64 un...
Well this might help you out then.
