Are you going to reinstall after?
If not, delete the program files folder, and run ccleaner's registry tool.
http://ccleaner.com
SOURCE: uninstall PrintMaster Platinum 15 but have to reinstall access de
Make sure you can see all the files. (My computer --> Tools --> Folder Options ---> View (tab) --> <Select 'Show hidden files ...' option.
Find the folder you have indicated.
C:\DOCUME~1\Jan\LOCALS~1\Temp\{A35C2323-3CEA-405C-9569-EF5DDE930B2F}
Delete that flder.
Restart the computer and reinstall the software.
SOURCE: i have vista, tried to
Here is a link to their website which describes how to manually remove the software from the hard drive. Let me know if it doesn't work and we can try some other options.
http://www.broderbund.com/c-26-support.aspx
SOURCE: Help! I used Dell system restore
Hi there! Let me see if I can try and help you. When you say your computer hangs up, do you mean that the install fails, or just seems to stay there? Does it come back with an error, or does your computer hang completely?
My first suggestion is that you try to upgrade to version 15 from version 11. When it's trying to install the fonts, unless something comes back as not responding, or your computer hangs up, be patient. Fonts are a lot of very small files that take a longer time to copy than just one big file. How long have you waited in the past?
If that doesn't work, I would uninstall all version of PrintMaster - if you come across any troubles, use the program found here to help uninstall - http://majorgeeks.com/downloadget.php?id=4459&file=15&evp=fe1c76da3437592326a3d668d72bf8f5
Restart your computer afterwards and then before launching any other programs try and install version 15 from scratch. Get back to me with your results and the answers to my questions and I'll be here to help! Good Luck!
Alex
