Hi
have you restarted the laptop since you un installed the smart pad driver
because normally windows will re install it on restarting
do you have an external mouse to use temporaily so that you can try the windows updates
they may offer up a driver for the touch pad
or go to
start
control panel
add new hard ware
find the touchpad and click install
or go to the official website
as you have not stated what operating system you are running i cannot find the exact driver for you
but you can search the operating system and then find the touchpad driver
http://support.asus.com/download/options.aspx?SLanguage=en&type=1
good luck
hope this helps you
many thanks
Install ETD smart pad driver software
Click Start/Control Panel and
look for the Mouse and open it to check the mouse properties. Make sure
you don't have the touchpad disabled.
Some models will allow you to toggle the touchpad on or off by clicking on the
button that is located at the top of the touch pad in the middle.
Some models will allow you to toggle the touchpad by tapping twice in the upper
left hand corner of the touchpad.
Some models will require a keystroke to toggle the touchpad. Press and
Hold the ALT or FN function key located at the lower left portion of the
keyboard, then hit the key that toggles the touchpad. The correct key to
hit will have the icon of a finger pointing at a square that represents the
touchpad.
Download and reinstall the touch pad drivers.
Get online and got to
www.google.com In the google search box type: "ASUS Support"
(without the quotes and put your manufacturer name before Support). Look
for downloads and drivers. Enter your model number and operating system when
requested. Download and install the Touchpad drivers.
