Hi C-2a03 is a magenta toner cartridge eeprom access error. You
can clean the connections between the toner cartridge and the machine if dirty.
Try reinstalling the toner cartridge, if the cartridge is bad it should be
replaced, if the cartridge is fine then the PWB-M should be replaced. Hope this
helps...please post back for further assistance. Daniel
Power board
You can buy the parts from this link
Thanks for rejecting the solution even though you got correct answer
If you want to do this repair yourself please check this service manual for your unit and thanks again.
That's fine, yes that is the part
You're welcome.....Thanks again :)
Clean the connection between the toner cartridge and the machine if dirty. 2 Reinstall toner cartridge. 3 Check the harness for proper connection and correct as necessary. 4 Change toner cartridge. 5 Check that CN29 harness on PRCB has a ferrite core. If not, attach the ferrite core to the harness. 6 Change PRCB.
Hello.
Just wanna make sure first if you are sure it is error code: C-2a03? Because code errors for your printer are usually " letter - 4 numbers"
hi, yes that code is correct
My bizhub c550 ig giving me an error code
c-2a03 can any one tell me what went wrong as soon as possible , thank you
Hi Daniel,
what part is PWB-M stand for?
Thanks
do you have a part number or name for pwb-m
Thanks
is it difficult to replace by myself ? where is this part located?
Hi Daniel,
Sorry about that i didnt mean to reject the solution, just trying to make sure that 's the problem for sure before i order the parts and is this link http://www.arcservicesco.com/anon/itemDe...
the correct parts i need , thanks for your help
Thanks for your help
Thank you very much for your help, i already accept the solution. And thank you for your understanding.
