It has a convergence issue how do i fix it
Did this problem just occur, or does it come and go?
If it just happened and it's continually doing it, it's most likely in the convergence circuitry. Most of the repairs on PTV are changing out modules. Problem occurs, what module exactly is involved, convergence usually has convergence output, pincussion, convergence drive and power supply. Which one? Without proper internal troubleshooting, hard to guess.
If the problem comes and goes, it's probably bad solder connections, PTV's are notorious for bad solder connections. When all the TV manufacturers removed silver from their soldering, using only tin and lead, lots of problems occurred since.
