NAD C350 2-Channel Amplifier Logo
Posted on Aug 20, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can i connect my Mordaunt-short 308 Subwoofer to NAD C350? Please help... Thanks
Anonymous
Level 3:
  • Master 8,546 Answers
  • Posted on Aug 20, 2011
Anonymous
Master
Level 3:
Answers
8546
Questions
Helped
2766004
Points
24828
Output voltage Mordaunt Short MS308
Most makers specify the transformer as a safety part which can only be replaced with a manufactures specified part. Contact them for the correct part. If you can't get one from them, then replacing it with a none recommended part, could pose a fire risk.
Which is the output voltage of transformer (the part number is SY-76D30085B 150e7630085)? Thanks if you could help me. Regards Jean-Louis
If you are looking for the specifications for this transformer to replace it, then don't bother. Makers like transformers replaced with exact parts by them, for safety reasons. You have the part number just find out who has it, or contact the maker for a supplier.
If you just want to know the voltage a multi-meter will tell you that.
No sound from sub
  1. Are the stereo speaker wires run to the subwoofer and out to the stereo speakers
  2. Make sure the notch filter is off
  3. Refer to the manual on line: http://www.manualslib.com/manual/105794/Mordaunt-Short-Ms909w.html?page=7#manual
  4. READ THE MANUAL
I own a Mordaunt-Short ms 907w subwoofer. It is
Hello. I appreciate this is an old post but in case someone still has one of these.I just got one in for repair today. Get two rca connectors and short them out so the input is grounded. If this fixes the problem then it is coming in through the inputs. If not then the two large filter caps need replacing. Another problem these units have is the glue that holds the small filter caps etc corrodes the board after a few years. Clean it off, repair the tracks and coat the board with pcb lacquer.
2answers
How to connect a mordaunt short ms907 subwoofer?
I guess you don't have the owner's manual for this?
You can get it here:
MS907 Subwoofer manual
The manual contains connection info.
Nad c350 no power at all
check your output stage for bad speakers cable or bare wire of cable touch the body of amp----short circuit speaker cable----bad speaker it self------ bad input cable or defective input device .
disconnect all and check if it is ok---start to connect one by one from input to outputs------if all above failed you must contact service center for help.
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Steve Sweetleaf
Steve Sweetleaf
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
