There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
SOURCE: I have an LHD6594EBL dehumidifier that won't
Sue, if you haven't noticed any water draining from the hose recently, it may be that the hose connection and tubing of the unit are clogged and the drained water pressure is causing the unit to show "Bucket Full." Also, if the bucket is not properly in place, whether you use the drain hose or not, it will cause the unit to stop functioning. You know how to correct that, so I won't go into detail on that issue.
To unclog the drain, you will need an 18" long, plastic Zip Tie or something similar (NO wire coat hangers though) that will fit into the hose connection. TURN THE UNIT OFF AND UNPLUG IT. Then carefully insert the Zip Tie and continue to push it in until you reach the bend in the tubing. You will have to carefully work it past this bend, until it either bottoms out or you run out of usable Zip Tie. Now, while rotating it, slowly pull it out and be prepared for some water to follow.
Hope this helped you troubleshoot and solve the problem.
SOURCE: I have a LG dehumidifier
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
SOURCE: Dehumidifer FDD40J6, probably 10 years
The problem lies in the way the bucket is reinstalled or the float valve (if yours is so equipped) is stuck in the UP position.
Remove the bucket for it's holder and check for the float valve. If it is stuck in the up position, jiggle the arm to make it return to the down position. Be fore you reinstall the bucket, look at the back wall of the bucket holder. There you will see a trigger switch. It's the bucket safety removal switch. Check it to make sure it's still intact. At 10 years old it may have broken OFF. If it appears to be be intact, install the bucket "squarely" into the bucket holder from top to bottom. Being sure that it makes firm contact with the bucket safety removal switch. When installed correctly, the bottom of the bucket will not tilt down at all.
Also, check the air intake filter as it may be dirty of clogged.
Hope this helped you to troubleshoot and solve the problem. Thanks for choosing FixYa.
