Ovens Logo
Posted on Sep 07, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
AEG D2160 Double Oven - electrical fault
Lower/main oven bulb has blown and tripped circuit breaker. On replacing bulb and switching CB back on, main oven fan and light stay on, even when oven selector is off, albeit elements do not heat up. If I select the oven and turn on, it works fine, heats up etc. Only way to turn lower oven light and fan off is to set to auto, then reduce cooking time to zero, this works. But as soon as return to manual setting, the lower fan and light come back on. Any assistance appreciated. Thnaks Rod
westting housee
Level 1:
Habit-Forming:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 19 Answers
  • Posted on Nov 09, 2021
westting housee
Contributor
Level 1:
Habit-Forming:
Welcome Back:
Answers
19
Questions
0
Helped
8080
Points
59
<a rel='nofollow' href="https://www.alalmya.com">???? ????? ????????</a>
<a rel='nofollow' href="https://daewoo.alalmya.com">???? ????? ????</a>
<a rel='nofollow' href="https://lg.alalmya.com">???? ????? ?? ??</a>
<a rel='nofollow' href="https://toshiba.alalmya.com">???? ????? ??????</a>
<a rel='nofollow' href="https://kiriazi.alalmya.com">???? ????? ??????</a>
<a rel='nofollow' href="https://indest.alalmya.com">???? ????? ?????</a>
<a rel='nofollow' href="https://whitewhale.alalmya.com/">???? ????? ???? ???</a>
<a rel='nofollow' href="https://samsung.syant-gahaz.com">???? ????????????</a>
<a rel='nofollow' href="https://ariston.syant-gahaz.com">???? ????? ???????</a>
<a rel='nofollow' href="https://ideal.syant-gahaz.com">???? ????? ??????</a>
<a rel='nofollow' href="https://fresh.syant-gahaz.com">???? ????? ????</a>
<a rel='nofollow' href="https://frigidaire.syant-gahaz.com">???? ????? ????????</a>
<a rel='nofollow' href="https://carrieregy.xyz/">???? ????? ??????</a>
<a rel='nofollow' href="https://westing-service.com/">???? ????? ????? ??????</a>
douglas smith
Level 3:
President:
  • Master 1,462 Answers
  • Posted on Sep 07, 2008
douglas smith
Master
Level 3:
President:
Answers
1462
Questions
0
Helped
898189
Points
3964
You may find that one arm of the oven selector switched has fused to its contact.
AEG oven tripping rcd at random points?
An RCD tripping points to an earth leak because that is what they are designed to do.
Check the wiring and pay special attention to the insulation.
Oct 07, 2023 • AEG Ovens
1helpful
Hi I have a 4year old Lamona 4601 double oven, the top oven/grill works fine but when I turn on fan oven it trips the power on the main house fuse board.
When the main breaker trips it indicates current is escaping from the circuit to ground.
If it is a micro-circuit breaker that trips it indicates the circuit is consuming too much current - a short circuit.
Either way the wiring or the oven elements have a fault and need attention.
Dec 20, 2017 • Ovens
Have replaced burnt-out element in main oven. Red light comes on when control turned, but no fan or heat.
an open circuit indicates infinity which means no ohms and what the element should read is a closed circuit. open is bad and needs replacement as for the no fan check for loose wire or power issue also might want to check for a blown fuse
May 06, 2015 • Ovens
Tried removing element from bottom oven, with the bottom oven selector on to provide some light. As I pulled the element out one of the terminals touched the casing and caused the light to go out, the...
More than likely you have tripped the house circuit breaker or fuse. If you know where the house fuse box or circuit breaker panel is check to see if either one side of the two 240 fuses is blown or one of the two tied together circuit breakers is tripped. If it is a breaker then shut off both breakers completely and then snap them both on completely or they won't reset. It is rare that an oven has a fuse internally. There can be thermal fuses but they will trip when the temperature is out of range.
Main oven trips electric when switched on top oven works fine also grill . did notice that fan was making a noise
If the fuse or circuit breaker is tripping it is most likely a short circuit in the oven element.
How do i reset the oven after a power failure?
If your oven won't heat at all, the most likely problem is a blown fuse or a burnt out element. Assuming you're not attempting to repair an antique, your oven will have a clock. If it has also stopped working, it's safe to assume the oven is not getting electricity. Check your circuit breaker box and reset the breaker if necessary and see if this fixes the problem. If not, cut power to the oven at the breaker box before going any further. Note that your oven runs on 220 volts. There should be a double switch on the circuit breaker board controlling power to it. If not, there will be two single switches that need to be tripped to cut power to the oven.
Even if you didn't find a blown circuit breaker, the problem could still be a blown fuse. Some older ovens have their own set of fuses located under the range top, in the back of the oven space, or behind the oven. Inspect the fuses and replace any that have blown with one of the same amperage. Your oven might also have a circuit breaker with a reset button on the control console or on top of the oven that needs to be reset.
If you are still confounded, pull the oven away from the wall. If it is a range/oven combo, make sure it is plugged securely into the wall. If it is a stand-alone oven, inspect the wiring in the junction box to make sure everything is tightly connected and the wiring doesn't show any signs of damage.
1helpful
2answers
Neff U1421 main oven trips the circuit breaker.
It might be that the breaker is overloaded and it's no longer supporting the load of all the appliances together.If you do not want to change your breaker you can still use your oven by switching off other appliances that is running while you are using the oven
1helpful
AEG Competence D2160-1m2 (double oven)
You neede to replace the oven element.
This is located at the rear of the oven compartment behind a removeable cover.
3helpful
2answers
AEG Competence Double Fan Oven Fault
Sounds like oven element is faulty, disconnect it and try again, if it does not trip, then it is definately the element..
It is easy to replace.
Plz leave feedback.
Bottom oven of dacor double oven
I found the lower circuit breaker had been tripped. That didn't fix the problem but upon further inspection whoever had worked on the unit years ago had dropped a screwdriver that had lodged between the oven wall and the rear casing and shorted out the lower heating element. I removed the screwdriver and oven works fine now. I don't think that will solve the cmmclow problem but maybee the curcuit breaker is tripped.
Top Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you an Oven Expert? Answer questions, earn points and help others
